Cleaning Cloth on Rear Deck and Side Curtain Airbags
So I dynamatted my rear deck today and when I was taking off the rear deck cover and back side curtain airbag covers I managed to get some grease on them with my hands and now I have light hand and finger prints on the pieces. What would you guys suggest using to clean them up a bit?
laundry detergent, do no scrub them just gently rub it off and do not soak it with alot water.
Don't know where you're located, but in Canada we have a very powerful, yet very delicate degreaser called Hertel Bio Plus. The stuff is strong enough to remove 2 year old oil stains from paving stone with a 5 minute soak and rince with water, but also delicate enough to clean the material that covers the gazebo. My buddy was a bit tipsy and managed to smoosh his burger on the area around the handle above the door, pure grease mark. A slight spray of hertel, wipe it a bit with paper towel and remove as much as possible using vacuum cleaner with that thin nozzle the size of half your pinky finger. Let dry and do a second application to remove the rest.
Not sure what grease you've wiped there but you can maybe go for one or two more applications. Regardless of how you do it, its non toxic, it wont stain, or dissolve anything but grease.
