Changing console lamps on 06 Auto TL?
Old May 29, 2010 | 11:12 PM
cristphoto's Avatar
I just noticed last night the light(s) in the floor console that illuminate my automatic shifter are out. Is this something simple to change or does the dealer have to handle it? If simple does anyone have the procedure? Thanks. Steve
Old May 29, 2010 | 11:36 PM
RonJonTL757's Avatar
Former Whyner
Meh its just a bulb. Man Up
Can u be more specific on floor console.. u talking about the little blue ones?
Old May 31, 2010 | 11:31 AM
cristphoto's Avatar
Its the bulb in the console itself - not the blue ones in the ceiling. Is it easy to get to? Thanks.
Old May 31, 2010 | 11:49 AM
nfnsquared's Avatar
Are you talking about the bulb that lights up the center console storage box? If so, it is a PITA to replace. You can't get to it from inside the box. The white cover inside the box is permanently attached. The bulb assembly is removed from the backside. You have to remove the cup holder assembly to get to the backside of the bulb. There should be some scans of the steps necessary to remove the cup holder assembly in the 3G garage. Look for short shifter install or usa spec install or led lighting install.
Old May 31, 2010 | 03:03 PM
cristphoto's Avatar
I'm talking about the bulb(s) in the console area that light up gear shift indicator (park, reverse, drive, etc.)
Old May 31, 2010 | 04:24 PM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
VVV:
Sep 17, 2015 10:16 AM
HydrasunGQ
Sep 14, 2015 10:14 PM
Aleax
Sep 11, 2015 11:31 AM
ellisd03tls
Sep 8, 2015 04:17 PM
usdmJON
Sep 4, 2015 12:59 AM
