Changing Brake Fluid
use the DIY on brake fluid bleeding in the brake pad replacement DIY
Bleeding means you know there is air,
flushing means all was ok- you are simply pushing old fluid out and new fluid thru the system until clear fluid comes out
buy a $2 turkey baster to remove `most` of the fluid from the master cyl and transfer to plastic drink bottle- dont uncover the holes or you will introduce air and learn what Bleeding the system is about~
mada51589
05-03-2022 08:54 PM
ulrblitzer
09-24-2015 07:42 PM
