Changing Air Cabin Filter. Help!
I'm in the process of changing the air cabin filter of my 04Tl. I've removed all components (glove box, connections, etc.) with no trouble. Im unable to remove the filter unit to replace the filter. There are two clips on the side of the unit that I can't figure out which way to push, pull or bend backwards the two clips that are located on each side of the filter harness. I'm nervous about breaking these plastic clips. What am I doing wrong?
All About Trance
Push them inwards and then pull towards you.
FOR SALE - BM
^---- what he said.... i just changed mine when i put my EDFC in.... unbelievably easy to do... litteraly i think it was like 2 screws total to remove...
1 Post
Originally Posted by mahaloco
How do you remove the glove box?
I finished mine last weekend and I must of pulled that thing out like 10 times because I couldnt figure out how to put on the black thing on the side, but after looking at it I figured it out.
push the tabs inward as you are pulling out. push the left one to the right and the right one to the left
0---> <---0
0---> <---0
