changed my tranny filter. some tips
Old Dec 2, 2009 | 04:57 PM
libert69's Avatar
18psi
this applies to 04-06 AT
wasn't a hard job at all. just make sure to have the right tools. a small 10mm socket wrench is what u need. there's not a lot of room to work
remove the stock airbox.
remove the bolt for the ground wire and tuck the wire out of the way
remove the 3 10mm bolts holding the transmission filter cover
remove the 14mm bolt for the bango fitting
remove filter
leave the spring inside the housing
replace or re-use the rubber gasket
replace the o-ring
replace the 2 washers on bolt for the bango fitting
bolt everything back up
some tips
stuff a lot of paper towels around the whole area where the filter is. you will lose about 2oz's of tranny fluid. i used about 15 paper towels and pushed some of them into the small spaces with a long screwdriver. i had no spills on the floor and no left over fluid on the tranny.
when re-inserting the spring, feel around inside where its supposed to sit. it feels like there a bunch if little hooks in there. the spring will hang loosely but will not really grab onto anything. slide the filter in SLOWLY. if u bump the side of the filter housing then spring will fall off. don't worry, you wont lose it. just try again.
once the filter is back in and u line up the cover, you'll have to push pretty hard to get the cover back on because of the new o-ring. once its in you'll hear a suction noise. it seems like its pushing all the air out.
parts
007 25450-RAY-003 ELEMENT (ATF) x1
021 91301-RAY-004 O-RING (48.5X2.95) x1
024 94109-12000 WASHER, DRAIN PLUG (12MM) x2
this is what my filter looks like after 106k miles. no metal shards or debris in there
any questions feel free to ask
Old Dec 2, 2009 | 05:52 PM
djonyx88's Avatar
onyX.
it show that filter for the honda element for the tl ?
Old Dec 2, 2009 | 05:57 PM
libert69's Avatar
18psi
im not sure if its the same filter for both cars or if "element" is what they call the filter. either way its the right filter for the TL
http://www.acuraoemparts.com/delray/...All&vinsrch=no
Old Dec 2, 2009 | 07:44 PM
KN_TL's Avatar
They call the filter an element, it's not naming a car model
Old Dec 3, 2009 | 07:54 AM
Schulminator's Avatar
it's 4:20
BTW: These parts do cross over to Honda part numbers, as I picked up all my parts from my local Honda dealer the other day. I will be changing the filter on my Christmas break....
Thanks for the write up..
Old Dec 4, 2009 | 12:37 AM
libert69's Avatar
18psi
i should have taken more pictures and made a DIY. yup, same parts for hondas as well.
Yikes
May 3, 2021 04:29 PM
mugen_kid
Nov 13, 2015 10:38 PM
Junior Noboa
Sep 21, 2015 06:28 PM
Aleax
Sep 11, 2015 11:31 AM
michaellong77
1G CL Problems & Fixes
Sep 11, 2015 12:54 AM
