CEL P0443 code?
CEL P0443 code?
Hey guys,
Had the CEL light up today code came up 0443 anyone have this? tried searching didnt come up with much
code reads
P0443. Evaporative Emission Control System Purge Control Valve Circuit
Any clues on fixing it?
code reads
You searched and didn't come up with much? This was the first link when you type that code into google.
http://www.obd-codes.com/p0443
To cause a P0443, there has to be a problem with the purge control CIRCUIT, not necessarily the valve. Usually they are a unit housing the valve and the solenoid as an assembly. Or it could be comprised of a separate solenoid with vacuum lines to a purge valve. That said, it could be any of the following:
Bad purge solenoid (internal short or open)
Wiring harness chafing or rubbing another component causing short or open on control circuit
Connector worn, broken or shorted due to water intrusion
Driver circuit inside powertrain control module (PCM) is bad
EvilVirus (12-03-2013)
Jamus22
06-11-2023 10:08 AM
