carbon fiber style front console trim
is this the trim that matched the factory carbon fiber in the center console?
http://www.hondacuraworld.com/Mercha...egory_Code=ATL
Full of water...
get it, i love the way it looks should have been stock though.
i would look around first though, you may be able to find it cheaper on ebay.
^ Ok that's what I want to know.
- Is this OEM?
- Does it just paste onto the stock plastic or is it the whole piece itself?
- If it is glued on, can it be easily removed?
Thanks guys,
Chad
- Is this OEM?
Thanks guys,
Chad
Too Fast TOO FURIOUS
- Is this OEM?
Thanks guys,
Chad
- Is this OEM?
Thanks guys,
Chad
2. they go over the stock plastic.
3. Not sure, but should be easy. I bet once you put them on, you don't want to remove them.
Man I dunno... Seems kinda ricey to stick something overtop of stock... I'd be afraid it will wear and fall off or start curling at the corners or something...
^ Damn it does. Hmmm, *pulls trigger*
Received 6,470 Likes
BukvaMan,
Thanks for the lead on nycdashes.com. I called them yesterday and am seriously considering purchasing a kit for my Type S. Did you buy from them? If you have their kit in your car, please post some pictures. I'd love to see what yours looks like before I buy.
I also have a lead for a trim kit from another A-Ziner who is supposed to get pricing for me. But I'd appreciate any pictures you've got.
Full of water...
i agree with all positive comments on these pieces. they are hard plastic, so they will not curl or whatever. they stick on, and will stay stuck as long as clean the surfaces properly. even if they lift, just use a silicon glue or something, thats what i had to do on the rear pieces. and they match perfectly, so you cant go wrong. like many have said, they should have come stock.
hmm these looks great, i was very interested in these, they look better with install pic! def gonna look into finding cheaper place for these. but then again 40 bucks is not too bad. more CF ftw~
Originally Posted by GZR4DR
Website shows 06-08 TL. Can anyone confirm this will fit an 04?
2006-2008 TL Carbon Fiber Style Front Console Trim
2004-2006 Acura TL Carbon Fiber Style Rear Console Trim
Full of water...
if it fits an 06 it should also fit the 04. i know in 07, the base TL didnt get CF, but instead some sort of dark wood like trim. only the type-s got CF, but i am not totally sure if its the same as the 04-06, but i am pretty sure they didnt change it.
if i had to bet i would say it will work just fine.
09-04-2015 08:03 AM
