Car won't start
Car won't start
What's up guys hope everyone is fine. I had a issue today and I don't know what I did wrong but something happened. My car was/is blowing the fuse #9 which is accessory plug...so I decided to check the fuse and the outlets because the previous owner had a lot of dogs so I said, probably is dirty who knows...fine...I removed the center console bla bla bla but, when I put everything back the car didn't start and Idk wtf I did because, I didn't change any fuse or unplug any cable and now the car cranks but wont start. However, when I put the key in ignition the green dot light that appears next to the P isn't showing anymore. I'm a basic mechanic tuned but I have no idea about electricity, I would like to know if someone have any idea or suggestions. Thanks in advance
It is possible you did something to shifter and knocked it out of adjustment. Not catastrophic but if you took apart the center console it’s possible. There’s something called the transmission range sensor (I think) that needs to get adjusted or replaced when you can’t get it to read in P or other gears. I watched my friend fix one at a shop I worked at for awhile. I was in the car shifting the car while he was messing with the sensor. It took some time but eventually we got everything to read in the right gears and the car would start like it’s supposed to in Park.
I could be completely off on this. Haha
Benji013x
08-05-2019 07:15 PM
