The car doctor with 2004 tl problem
I was listening to a show called the car doctor on the radio and there was a small discussion about a problem with a 2004 tl. Here is the link if you want to here it. The discussion is in the first ten minutes and short, but if you want to hear it, here it is. This is a show on abc radio in new york.
http://podcast.wor710.com/wor/56642.mp3
Much regards flatfoot
its working
Originally Posted by Actuary
not working on my computer... maybe it's bad time of bad day
I just tried it. Do you have quicktime installed? It takes just a minute or two. Thats apples equivalent of media player. It is for pc,s also. I am using a pc.
Much regards
Just wanted to post the Acura TL info from the podcast...save you all the hassle to find the precise point in the file (06:44 - BTW)
Summary:
2004 Acura TL
Symptom: Sound - pulley belt sound when warmed up
1st attempt to fix: replaced exterior fan belt idler pulley assembly
Result: worked for an hour; sound returned
Final fix: idler pulley from the timing belt; bad bearing in the assembly
Summary:
2004 Acura TL
Zonian22
11-14-2015 01:20 PM
Zonian22
09-02-2015 08:19 AM
