Can I Turn Rotors/Bleed with Old Pads?
practicing nihilist
I'm pretty sure I have a slightly warped rotor. Brakes are fine and pads have plenty of life but I'll be selling soon and would like to try and get rid of the warping.
I would of course flush/bleed the lines.
you can flush the brake fluid at any time regardless of pad and rotor condition
The shake usually comes from the rotor itself, and you would have to resurface or replace to get rid of the shake, or take that cost off the selling price
for the TL- flush/bleed order is special- its driver front then clockwise around the car
LF RF RR LR
figure on 1+ qts to do a good job- use DOT4 fluid
LF RF RR LR
Using old pads on new/resurfaced rotors is fine as long you bed them in afterwards. Bedding properly will reshape the pad surface to the new rotor surface. Sometimes bedding alone can alleviate warped rotors as well. Of course it usually comes back after a while...
If the rotors are warped, then resurfacing usually only buys you some time. With the same pad compound and driving style, the problem usually comes back. I would at least try re-bedding before I went and bought new rotors though...
The best to go is just replace the rotor ... But for a temp fix the best is to resurface the rotor and bed in the pads so they match he rotors o doubt the warp will be gone for longer then like six months
mada51589
05-03-2022 08:54 PM
09-17-2015 09:01 PM
