Brembos
Brembos
I am thinking of changing the rototrs on the 6mt to a drilled rotor. Does Brembo make this upgrage i need brakes pad soon and i think im going to switch them up i love the look of them not to mention the peformance of them.
there were a few threads on this already, if you are simply getting them for cosmetic reasons then that's one thing. but for normal street driving most people recommend slotted instead of the cross drilled. the xdrilled(even tho most are cast) are more prone to cracking. since there is less surface areas braking perfomance might even go down. race cars compensate for the less surface area with bigger brakes.
i wam going to Road race it this year so i know the stock breaks are fine but i will genrate alot of heat when breaking at high speeds so maybe sloted will be better i have cross drilled on my other car with wilwood rotors and 4 piston breaks and there awesome
jmoney2001
09-11-2015 12:07 PM
