Brembo OEM replacement rotors
I have been researching for a while now to replace my oem rotors with cross-drilled Brembos.
Unfortunately I can only find the front ones. Any links to find the rear crossdrilled Brembo rotors?
AZ Community Team
Received 7,771 Likes
I've never seen 'em either.
Do youself a favor - get Racing Brake Slotted and/or Drilled. Contact Mr HeelToe. Check Kennedy's thread at the top of this page for Pics of the RB Slotted.
OR
Look at the Rotora Slotted and/or Drilled from Excelerate.
OR
6-SPEED LOVER
IM BUYIN MINES FROM THEM SINCE THEY ARE CLOSE 2 MY CRIB.... THEY IN NJ RT.46
http://store.zeckhausen.com/catalog/
AZ Community Team
Originally Posted by JuamPs 69
Yeah I saw those posts earlier...Whats your opinion between those and Brembos?
I've got an '07 TL-S with stock rotors and pads. Front Pads and calipers are Brembo, not sure about the rotor. Pads are about 70% worn.
I've also got an '02 TL-S with RB Slotted Fronts, StopTech Slotted Rears and RB ET500 Pads. Brand new.
Both have SS Brake Lines.
Right now the '02 has MUCH better pedal feel - much firmer. And, IMHO stops as good, if not better, than the '07. No squeaks, squeals or shimmy and minimum dust.
I am VERY happy with the RB Rotors and Pads at this point. I will not hesitate to put them on the '07 once the rotors go (probably after the 2nd OE Pad set).
Trolling Canuckistan
Can't give you any real info on the rotors you are looking at, but I have Brembo's (not slotted or drilled) on my Prelude and I am very very happy with them.
iWhine
Originally Posted by Escobar7
Hey does any1 know what parts/part # i would need to change my calipers to the OEM Brembo calipers??? I think its just the brackets and the calipers but not sure?!?Please Help...
https://acurazine.com/forums/showthread.php?t=176714
https://acurazine.com/forums/showthread.php?t=157272
psheu List
"1. Brembo Calipers/pads
2. knockles (where the calipers, and rest of the rotor/wheels mount on to.) and bearings
3. last portion of the brake line that connects the hard tub of the calipers.
4. a larger rotor" Am thinking Rotora
Originally Posted by LukeaTron
Knockles, lol. I'd hate to get punched with a fistful of those.
asahrts
09-04-2015 05:55 PM
