Brembo Brake Pad Replacement Question(s)
AZ Community Team
Received 7,771 Likes
'07 TL-S, 5AT (i.e. Brembo Fronts).
Looking for source information on Molykote M-77, I ran across this tidbit:
TSB 04-019: Brembo Brakes Squeal With Light Application. https://acurazine.com/forums/showthread.php?t=154245
So here are the question(s):
- If I use an Aftermarket Pad Set, is the Molykote M-77 OK, or is the new spec Brembo Grease preferred?
- Where can the Brembo Grease be obtained?
- Last, it appears that the OE Brembo pads are not shimmed. Is that correct?
I assume that if I got OE pads, the correct grease would be included.
Also, I am aware of aftermarket products (CRC Brake Quiet, etc) but am not asking about those; thanks just the same.
TIA.
....Service Bulletin
January 20, 2007
04-019
REQUIRED MATERIALS
Brembo Brake Grease: P/N 08798-9027
NOTE: Do not use Molykote M77.
January 20, 2007
04-019
REQUIRED MATERIALS
TIA.
AZ Community Team
No knowlegde of the M-77 on aftermarket pads or sourcing for the newer spec Brembo Grease?
Unofficial Goat
If your DIYing it, when you buy the OEM pads both sets come with a little tube of the Brembo lube, but there is more than enough in 1 tube for both sides, I'm willing to bet the service guys at your local dealer have quite the stockpile of extras kicking around, simply asking one may get you what you need.
AZ Community Team
Originally Posted by sho_nuff1997
I have to do my brakes next weekend, I was wondering this as well. I assumed the Acura dealer would have some.
Thing is I am not sure I am going with OEM pads and have some Molykote M-77 left over from a previous 2G pad replacement.
So I am trying to figure out if the Brembo grease is recommmended regardless of pad or if the Moly M-77 will be good with aftermarket pads on the Brembo Caliper. The more I think about it, the more I think Molykote M-77 will be fine.
Also, trying to confirm that pads for the Brembo Caliper are shimless.
Team Anthracite
Originally Posted by Bearcat94
I figured if you bought OE Pads, you'd get the new pad grease.
well at least thats the case in Canada, and they come with a few packs grease
item 7
AZ Community Team
Originally Posted by tidus888
a friend of mine in acura parts mentioned that the pad set for 07-08 type-s with part number 45022-SEP-A60 (with shims) now replaces the original part number 45022-SEP-A52 for 04-06 brembo pad set (shimless)
item 7
item 7
I wonder if this is a response to the noise issues in previous versions (i.e. like the TSB in the original post)?
Oddly enough the '07 TL-S parts drawing does not show the shims (hence my question), but DOES have the same part number shown above (with shims).
Team Anthracite
I disagree with unanimity
I have aftermarket pads and rotors and they didn't come with any grease. Hopefully the dealer will have some laying around.
AZ Community Team
the picture is from TL-S Parts
Here is the drawing for the '07 TL-S
http://www.acuraautomotiveparts.org/...s=&view=normal
This is what made me wonder if the '07 had shims or not. I know at least one other MT ('06 I think, maybe '05) whose Brembo pads did NOT have shims. Even though the '07 drawing is "wrong" the part number (on the '07 TL-S parts list) seems right.
Unofficial Goat
Thanks, got that. But that drawing seems to be from an '08 TL-S.
Also notice the tubes of brembo grease by my foot that came with the pads, you get 2 of those tubes per caliper, the dealer techs probably have tons of them kicking around because 1 is more than enough. I think I have 2 left in my tool box.
AZ Community Team
Excellent. Thanks. So the "new spec" pads do come with shims and "new" grease, apparently for any MY TL w/Brembos.
Any opinion on whether aftermarket pads will benefit from the shims of new caliper grease?
If so, I might go OE this time just to get those materials.
I am beginning to wonder if the misc complaints of after market pad noise are related to the lack of either these new OE items.
Team Anthracite
I went to the dealer yesterday and they didn't have any extra grease laying around. Now I am on a hunt for some grease. Any reason I can't use something like this?
AZ Community Team
Usually at the local Auto Parts Store, they have single use packets of Caliper Grease. I think CRC is one of the common ones. Comes in larger sizes as well. The one I saw was also a Moly-Sulfide compound, very similar to the Molykote M-77.
I'm probably just being a granny, but I've heard so much crap about noisy pads and squealing brakes, I want to stay as close to Mfg's recs as possible.
mada51589
05-03-2022 08:54 PM
nanos
11-12-2015 08:41 PM
