Brake Pads replacement for TL-S??
Old Apr 11, 2012 | 10:31 AM
  #41
94eg!'s Avatar
#1 Super Guy!
I contacted Centric Parts about their 100 series OEM compound for the 6MT/TLS and they forwarded me to Dave Zeckhausen of Zeckhausen Racing. He tells me this about the pads:
Originally Posted by Dave Z
The D1001 shape is used by a wide range of applications, including the Caddy CTS-V, Chevy Camaro SS 6.2, Ford GT, Mustang GT500, Mitsu Lancer EVO, Subaru WRX STi, and Volvo S60R/V70R. Depending on application, the OEM supplier was either Jurid, Ferodo, or Galfer, providing compounds in 3 different friction ranges. All are characterized by low-metallic composition and are abrasive (vs adherent), have good low-speed bite (or are "grabby" depending on your perspective), and are relatively hard on rotors. Centric Parts is currently using the Jurid formula from the Volvo V70R. However, their choice of formula may change in the future.
For the majority of customers with Brembo calipers who want to maintain high performance, but at a more reasonable price, we suggest the StopTech Street Performance pads. These have good bite and friction, yet relatively low dust and noise compared to the OEM pads. Their extremely high fade resistance makes them usable even at the track, long after the pads that came with your Brembo calipers would have faded. I have them on my 2007 Corvette Z51 and have been unable to fade them during multiple track days. Yet they are smooth and quiet when driving on the street. I also have them on my BMW 540i and Chrysler 300C SRT8 and think they are the best street pads I've ever used.
I then responded telling him of my concern about the ABS/TCS/EBD systems requiring the OEM coefficient of friction. I also asked about proper break-in. This was his response.
I've learned that brake pad selection can indeed affect vehicle stability control and, to a lesser extent, ABS functionality. ABS is a closed loop (adaptive) system, so it learns from the way your brakes respond and rapidly converges on an optimal solution. However, dynamic stability control is open-loop, consisting of a series of discreet "hits" on individual brake calipers to try to force the car along the driver's intended path. If a car is equipped with significantly lower bite pads than stock, the car may take longer to stabilize, rendering that driver aid less effective.
The sort of testing that takes place during the design phase of a new vehicle's brake system was replicated by StopTech to validate or fine-tune a new big brake kit design. James Walker Jr. was leading the Corvette C6 vehicle dynamics team at General Motors (as a Delphi manager) when he was hired as a consultant to help StopTech come up with these brake tests. See: http://www.zeckhausen.com/Testing_Brakes.htm for a write-up I did almost a decade ago. The test equipment and procedures have become more sophisticated since then. It may be time for me to revisit this article!
The StopTech Street Performance pads are close enough to your factory pads to function well with your electronic stability aids and ABS. They are an abrasive pad, so they may chew away their own transfer layer with extended gentle driving. But they respond well to bedding and may even require occasion rebedding, if you're not an aggressive, late-braker. Without seeing your technique and your rotors, I can't tell if you bedded them sufficiently. But this should be your guideline for bedding: http://www.zeckhausen.com/bedding_in_brakes.htm. No legal departments involved here, toning the process down to make it safer. This is the ideal technique for virtually all pads.
Dave Z.
For those interested in the subject, and the time and patience to learn, there is some really excellent info contained in the links. He also pointed me to a book on high performance brake systems for those that enjoy extended reading.
Amazon Amazon
So what does all the above information tell me? You can't go wrong with any of the following pads.
- Acura
- Stoptech 309 series
- Centric OEM/100 series
But I definitely wouldn't use anything less.
Old Apr 11, 2012 | 11:03 AM
  #42
turbo_oxide's Avatar
After reading this thread, I think I'm going to stick with OEM pads instead of aftermarkets (for now) because I'm keeping the stock rotors.
The car is at 39k miles (don't know if these are original pads), but the front pads are ready to call it quits pretty soon. Going to grab OEM pads from http://www.acurapartswarehouse.com/ and just change those. The rotors look fine to me.
Although when I called the stealership to get a quote on parts/labor, they were annoyingly persistent that i HAD to change the rotors since it was a Type-S.
I was just going to pop the wheels off and change the pads and leave it at that. Anything else I should be concerned about?
Old Apr 11, 2012 | 11:24 AM
  #43
94eg!'s Avatar
#1 Super Guy!
Yeah stealership will always tell you that. In the UK, nobody ever swaps or machines rotors for pad replacements. They just replace them once they are too thin or vibrate to the point where a re-bed won't fix it.
Old Apr 11, 2012 | 11:33 AM
  #44
Azndjay's Avatar
MV612
don't forget if your replacing your brake pad might as well replace your fluids also, since the manual suggest new brake fluid every 3 years.
Old Apr 11, 2012 | 12:29 PM
  #45
dragonsking91's Avatar
Go Pats!
I think i will do this when ever i need to replace the brake pads again which mostly likely i will also change the rotors.
Old Apr 11, 2012 | 04:28 PM
  #46
94eg!'s Avatar
#1 Super Guy!
Here is what Dave had to say about mixing/matching front & rear pad compounds...
The Acura TL rear pads are a combination NAO & ceramic material with an FF friction rating, which is the same friction rating as the StopTech Street Performance pads AND the factory front pads. The 100-Series pads in front, combined with the StopTech pads in back will yield the closest overall dynamics at all speeds to factory performance. But StopTech pads all around will work fine and be smoother at low speeds. Since these are all close in overall friction levels, the only issue is personal preference on low-speed behavior.
Dave Z.
Based on this info, I will go with Stoptech all around when I change pads simply for the reduced dust. Lower cost and higher temp operating range are definitely an added bonus.
Old Apr 11, 2012 | 11:12 PM
  #47
cisco kid's Avatar
i need to replace my rotors at this time. I have an 08 TL Type S with 50K miles on it. The rotors have been turned and are now too thin for me to bother turning again. I am strongly considering the Brakemotive slotted and drilled rotors and Stoptech Street Performance pads for front and rear. I was wondering if anyone can comment on this combination and where can I order the Stoptech pads for the best price shipped within Conti US?
Old Apr 12, 2012 | 01:59 AM
  #48
Go Pats!
pads
http://store.excelerateperformance.c...e/g-61616.aspx
rotors
http://store.excelerateperformance.c...s/g-63863.aspx
Old Apr 13, 2012 | 02:39 PM
  #49
How long do the stock rotors on TL-S's typically last everyone (on OEM pads)?
Old Apr 13, 2012 | 03:52 PM
  #50
Azndjay's Avatar
MV612
mine were look good at 40k and i think i could of run them til 65k til it would need to be replace or turned. i just replace them all with steinless steel lines and fluid with power slot n stop tech all at once ,so i dont have to worry til later again.
Old Apr 14, 2012 | 10:20 AM
  #51
Go Pats!
ok i just got my Michelin pilot super sport installed and the car drives like day and night compare to the stock tires. The car feel so stable and acceleration is a lot better now. the guy that installed my tires saw my stoptech brake pads and recommend me to change my rotors to drilled/slotted since the performance brake pads are really aggressive and will eat up my rotors. He told me he had hawk pads with stock rotors and after one year the rotors was really bad. My question is, have anyone experience this kind of problem while running stoptech / hawk performance pads???
Old Apr 14, 2012 | 10:28 AM
  #52
Azndjay's Avatar
MV612
some people dont like drilled rotors because they tend to crack..you should be good with the powerslot and stoptech pad combo on xlr8
Old Apr 14, 2012 | 10:34 AM
  #53
Go Pats!
this one??
http://store.excelerateperformance.c.../i-338784.aspx
Old Apr 14, 2012 | 10:40 AM
  #54
giggity's Avatar
Slotted rotors help cooling and excavating water, just give you a funny noise when applying breaks. if you are a hard breaker and get them hot I would suggest cryo treated rotors.
Tires, suspension, and breaks were my first upgrades on all my cars. Can't wait to do my a-spec suspension swap.
Old Apr 14, 2012 | 10:45 AM
  #55
Go Pats!
I want to use the oem rotors right now if i don't have to change it that's why i wonder if any member on here experience anything with stoptech/hawk performcne pads with oem rotors.
Old Apr 14, 2012 | 11:03 AM
  #56
JJH's Avatar
JJH
Originally Posted by DMZ
It's very rare for people to complain about noise with the OEM pads. Sounds like they may not have been installed correctly. Also, I seem to remember the was a TSB about this.
There was a TSB for brembo squeal.
Old Apr 14, 2012 | 11:04 AM
  #57
LionRock85's Avatar
I would say Hawk's are pretty good brake bads and reasonable prices on the xlr8 website.
Old Apr 14, 2012 | 11:16 AM
  #58
94eg!'s Avatar
#1 Super Guy!
If you didn't have problems with the original OEM rotors, then they are perfectly fine for how you drive. Stoptech pads won't be very different at all. Slotted are good if you go racing, but I would not waste extra money on them for street. If I were to buy new rotors, I would go with Centric's non-directional Hi-Carbon option.
Street rotors options by Centric/Stoptech (cheapest to most expensive):
- C-TEK (cheapo) (121 prefix)
- Centric Premium (120 prefix)
- Centric Premium, Cryo (120 prefix C suffix)
- Centric High Carbon Alloy (125 prefix)
- Centric High Carbon Alloy, Cryo (125 prefix C suffix)
- Centric Sportstop Drilled, Directional Vane (128 prefix)
- Centric Sportstop Drilled, Directional Vane, Cryo (128 prefix C suffix)
- Centric Sportstop Drilled & Slotted, Directional Vane (127 prefix)
- Centric Sportstop Drilled & Slotted, Directional Vane, Cryo (127 prefix C suffix)
Semi-Race Rotors by Centric/Stoptech:
- Centric Powerslot, High Carbon Alloy, directional vane (126 prefix)
- Centric Powerslot, High Carbon Alloy, directional vane, Cryo (126 prefix C suffix)
Here is a link with all the options and helpful instructions on how to choose the right setup for you: http://www.zeckhausen.com/Acura/TL_Gen3.htm
The Cryo options I've only seen from TireRack: http://www.tirerack.com/brakes/resul...d+Transmission
Old Apr 14, 2012 | 11:36 AM
  #59
94eg!'s Avatar
#1 Super Guy!
After re-reading a few things, there is no guarantee any of these rotors have curved internal vanes for the TL. I know the ones for the Integra do all the way down to the High-Carbon version. Oh well.
Old Apr 15, 2012 | 01:47 PM
  #60
jungy4's Avatar
Well I finally had a chance to replace my front pads for my 06 6MT. Thanks to a lot of DIY threads on this site, it was a very easy job, a lot easier than conventional calipers with bolts. The right ones are the new Wagner Thermoquiet ones that I always have bought for all of my cars.
Old Apr 16, 2012 | 07:44 AM
  #61
DMZ's Avatar
DMZ
Head a da Family
Can you give us a report on how well those Wagner pads work?
Stopping power, dust, noise, etc.
I'm considering them for my next brake job.
Old Apr 18, 2012 | 07:43 PM
  #62
Timstandupguy's Avatar
I installed hawk pads on my type s and its quiet and its stops hard just like the brembo ones. the good feature from the hawk brake pads the dust is like a silver grey residue so it blends in to the wheels. i rarely clean my wheels because its not a lot of brake dust. which is what i love
Old Apr 18, 2012 | 07:53 PM
  #63
just some info buddy
I installed hawk pads on my type s and its quiet and its stops hard just like the brembo ones. the good feature from the hawk brake pads the dust is like a silver grey residue so it blends in to the wheels. i rarely clean my wheels because its not a lot of brake dust. which is what i love.
Hawk HPS are very good brakes. They Cost me 200 Bucks but i believe in good quality products so you get what you pay for. i Dont do track just normal highway and city driving so my pads are durable and quiet and show very low brake dust
Old Apr 18, 2012 | 08:53 PM
  #64
anthracitecl's Avatar
^ $200.00? Why is it so $$$? I paid $103.00 for mine.
I installed Hwak performance ceramic pads for front on my TL this afternoon. My OEM pads still have about 70% life left. OEM pads make a lot of dust!!!! I can not stand on brake dust. and i'm gonna put my wheels back on soon. I don't wanna clean my wheels every couple of days.
Old May 10, 2012 | 07:40 PM
  #65
catesbros's Avatar
Originally Posted by mY sLOW UA6
^^^ If your car vibrates when you apply the brakes it means its time for new or resurfaced rotors.
Not necessarily, it could mean that your brakes need to be re-bedded in. I just learned this from reading on the heel toe and stop tech sites
Old May 10, 2012 | 10:53 PM
  #66
I hate cars's Avatar
This thread is so full of fail! Nice to see 94eg in here clearing some of it up. For starters:
You don't want drilled rotors. Every drilled rotor will crack given enough time... period.
There is no need to machine a rotor during a pad change unless they're warped and in most cases it's just brake pad material transfer that's stuck to the rotors.
Slotted are fine for street use. Unnecessary but won't hurt anything.
Tires determine stopping distances, not the brakes or pads. If you want the absolute shortest stopping distances you should have gone with better tires, not over priced Michelins.
If you're not having brake fade issues, you don't need better pads, not as far as performance is concerned.
Hawk makes some decent pads but they're kind of like Optima batteries, living off of an old reputation. Many good or better products for less money.
The Stoptech street pads have excellent fade resistance and good cold bite. The friction changes just a tiny bit when they get hot but they're very consistent.
The Brembos are only 12.2" in diameter, the TL weighs 3,500-3,700lbs without the driver with most of the weight on the front tires. A full weight TL will fade the stock Brembos under track conditions if you're not careful. They're adequate but they're not exactly oversized for the weight of the car. You should never have to worry about brake fade with a good street pad like the stoptechs even with spirited street driving but if you ever track it, you will need a race pad. I have 13" brakes up front, my car weighs 3,800lbs with me in it and I can fade the brakes if I'm really hard on it.
If it doesn't rain or snow a whole lot in your area you might consider removing the dust shields behind the rotors. This made a significant difference in cooling of my brakes, more than I ever thought it would. I've been through puddles, no issues ever.
Don't forget about brake fluid. #1 is getting new fluid in there because moisture is your #1 enemy, significantly lower the boiling point. You have two kinds of fade, pad fade, and boiling of the brake fluid. Pad fade usually gives you some kind of warning and they come back pretty quickly. Boiling the fluid happens all at once and it can take a while to get your brakes back. I've tried a few different brands in the Tl and so far I've had the best luck with Motul 600. I chose this fluid because not only is the dry boiling point high, the wet boiling point which is more indicative of real world performance is very high.
You'll tend to fade the pads first but fluid will boil over extended fun runs. The rotor surface runs way hotter than the fluid's boiling point almost all of the time so if you drive it hard long enough you're going to eventually transfer enough heat into the fluid to boil it. Coming to a complete stop with the brakes applied after a hard run can boil the fluid as well.
If it were mine, I would run the stock rotors, Motul fluid, and Stoptech street pads. That would be a very nice combo with zero downsides and pretty cheap as well.
Old May 10, 2012 | 10:58 PM
  #67
brz08tls's Avatar
I got the slotted rotors + pads combo from xlr8 and they have been perfect so far. No noise, dust is low, braking is decent. No complaints so far.
Had the autozone ceramics + rotors before and the pads just ate through the rotor in less than 15k miles. I would avoid ceramic pads that are too aggressive.
Old May 11, 2012 | 06:12 AM
  #68
gatrhumpy's Avatar
Chapter Leader
(Northeast Florida)
IHC, where did you get the 13" rotors, and I assume you had to make another caliper bracket to hold the larger diameter rotors?
Good information BTW!
Old May 11, 2012 | 08:06 AM
  #69
Guiltyox's Avatar
I can vouch for Hawk HPS Street pads. I replaced all of my pads (front and rear, simultaneously, for the best performance) with Hawk HPS Street pads, and they are amazing. The bite on them is, by far, noticeably better than the stock pads. I've also noted much less dusting than the stock Brembo's as well.
I would recommend replacing all of your pads at the same time, to get proper wear. For maximum performance, switch to StopTech drilled/slotted rotors (or the rotors of your choice), stainless steel brake lines, and change your brake fluid (make sure you know how to properly bleed them), with Motul fluid.
If you have any questions about them, please feel free to send me a PM!
Old May 11, 2012 | 09:40 AM
  #70
94eg!'s Avatar
#1 Super Guy!
It's XLR8's custom Stoptech Big Brake Kit.
Old May 11, 2012 | 09:43 AM
  #71
gatrhumpy's Avatar
Chapter Leader
(Northeast Florida)
I see. Thanks man!
Old May 11, 2012 | 10:28 AM
  #72
wall e's Avatar
TL=True Love
my brakes make noise too esp at low speeds, like pulling out of the driveway and stopping for traffic to clear. its not sqeeking or screeching, its a different sound, like creeking (i d k)
Old May 11, 2012 | 12:30 PM
  #73
Guiltyox's Avatar
This is normal for good street/performance pads.
Old May 14, 2012 | 12:47 PM
  #74
zzvi3ti3oi83zz's Avatar
4th Gear
Got my front (Powerslot) rotors and (Hawks) pads replaced on my TL-S 07 last week. Holding strong at 64K. This is my third pads counted the stock and first for the rotors. Also flush the brake fluid, first time too.
Ilove this site, it got tons of info )) - i was able to get the cold start noise coming from under the hood with for $2. aweeeesommme...
Check this out !! This is when i was trying to remove the DAMM screw from the rotors.
Another thing that i am not able to figured out yet is the (cluck cluck or click click sound like coming from the passenger side) every time accelerated from a completed stop.
Check this out !!! This is when i tried to remove the DAMM screws from the Rotors with the impact screwdriver.
second picture
Old May 14, 2012 | 01:01 PM
  #75
Azndjay's Avatar
MV612
yep had to drill mine out two times was a PITA.. tired impact gun also, but ended up striping the bolts.
Old May 14, 2012 | 01:13 PM
  #76
When you drill out the set screw, you need to use a large drill bit like a 7/16". You're not trying to drill through the screw, you're just drilling the head off. It should not take more than 5 seconds of drilling.
Old May 16, 2012 | 04:38 PM
  #77
saip15's Avatar
Is the cryogenic worth the extra money? Is there that much of a difference for a daily driver?
Old Nov 18, 2012 | 12:49 PM
  #78
ignition_key's Avatar
Type-S
Question
I just bought some Wagner Thermoquiet pads for my 06 6MT that are waiting to be installed. I always have bought this for all of my cars. I will find out how good these $50 pads are.
Can you tell us how your expedience has been with these pads?
Old Nov 19, 2012 | 12:14 AM
  #79
jungy4's Avatar
I love the Wagner pads. It is quiet, dusts less than OEM ones. I can't comment on stopping power because I never took my brakes to the limit when I had OEM pads.
Old Nov 20, 2012 | 09:11 PM
  #80
bonnhew's Avatar
i just put the wearever gold ceramic pads from advance auto parts and they are freaking great! cost me only 30$ and its soo worth the price.
