Brake Fluid Change - How many bottles do I need?
Going to being changing the Brake Fluid on my 08 TL-S next weekend, how many bottles of the OEM Acura Fluid do I need to purchase?
Also, is there an online store that sells OEM fluids?
Thanks!
Thanks!
AZ Community Team
Received 7,770 Likes
It's been a while, but I think I bought 4 and used 3.
You can get DOT3 Amsoil fluid that has higher wet and dry boiling points than many mass-market DOT4 fluids.
Make sure you do the bleed order on the Brembos correctly (link in this page: https://acurazine.com/forums/3g-tl-2004-2008-93/3g-tl-garage-faq-3g-tl-newbies-553554/).
takin care of Business in
Received 4,732 Likes
Any DOT 3/4 fluid will do...stay away from DOT 5...
in my 05 TL, I got 2, used 2....but since you have TL-S, I would double check....
I use a Motive Products pressure bleeder on my wife's '07 TL-S (and my '08 350Z), and used just about the entire liter of Ate Super "Blue". The next change you use the "Gold" fluid, so you can see when all the blue is flushed, the next time the gold, and so on. The pressure bleeder will result in almost no wasted fluid, and generally does a better job that pumping the brake pedal.
mada51589
05-03-2022 08:54 PM
ulrblitzer
09-24-2015 07:42 PM
