Best source for Brembo front rotors for 07 TL Type S???
Need to buy some front rotors for my 07 TL Type S. Bought a Brembo kit advertised as being for my car, and of course they gave me front rotors for a regular TL. Whats the best source online for Brembo front rotors for the Type S models? According to the Acura dealership, OEM part # is 45251 SEP A51. Anyone know what the Brembo part # is? Thanks in advance.
They might not make them for the front anymore. I got Brembo rotors for my 2006 6MT on Tirerack, but they don't have any listed for the 2007 Type-S. Even on the Brembo website, they only offer rear rotors.
https://www.brembostoreusa.com/produ...47&clev=0&hs=1
Latent car nut
Personally, I'd opt for Centric rotors over Brembos, but then, that's me.
I initially thought they had warped after starting to pulse after about 5K miles, but later found that it was due to uneven pad material deposits of the ceramic pads on the rotors. Threw some semi-metallic on there and the pulsing went away after about 50 miles (once the old ceramic pad material was scoured off the rotors). So apparently it was never really the rotors fault.
The Brembo's I got for my 2006 were great. Paired them with Akebono pads. I can vouch for Centric as well though. I have some on my 4G and they're working just fine.
Centric rotors have been my favorite. The black coating is holding up well.
horseshoez (07-29-2019)
Not really pushing these, but RockAuto has a sale on certain PowerStop products:
CRK2718 Front & Rear Rotor, Pads, Hardware kit $165.41
Not certain the additional 5% discount can also be used, but here's the code good until 9/22
11486483388182531
I just installed PowerStop pads on our '11 Optima Turbo, great so far.
11486483388182531
Man, thats a shame. Although not really surprising Brembo doesnt make them anymore since Acura didnt sell a lot of TL type S models. I definitely dont need anything for track use so racing rotors are off the table. Looks like Ill give the centric rotors a try. Can you guys recommend the cheapest place to get them online? I already have Brembo front pads, so just need the rotors.
Should also note I am open to suggestions for other good front brake rotors as long as they are around or under $200 for a front set. Dont want to spend too much more then that. Biggest thing Im worried about is if they will warp under occasional hard braking on the street. Thats why I like hearing feedback on personal experience. With all the chinese made junk out there nowadays with even a lot of the OEM stuff being made in China now, its basically a crap shoot as to what will hold up long term. All feedback is appreciated. Thanks in advance.
FYI-Brake rotors don't warp.
Latent car nut
FWIW #1, unless you bought your Brembo pads from an Acura dealer, then you have the cheap knock-off Chinese made Brembo pads.
FWIW #2, the OEM Brembo pads are made by a company in Italy.
I think your misconception is that rotors warp.
That misconception has been around for a while, so I don't blame you.
Read some of the posts above.
Rotor pulsation comes from uneven pad deposits in a vast number of cases.
In RARE cases, a rotor may be incorrectly machined, or may have rust pitting below the surface.
Or mechanical warping may have occured as a result of incorrect torque or a bent/uneven hub.
PADS, my friend, is what you should scrutinize.
A rotor is just a peice of iron. Iron doesn't soften enough to warp until you heat it to like 2500+F. Not just the surface...but deep enough to actually warp the plane.
Think about that.
You're not doing that with your agressive street driving.
Centric rotors work fine.
So do ones branded by Brembo.
Or Raybestos.
Or (name them).
You're asking the wrong questions.
"What PAD should I buy so I don't get brake pulsation"? is a better one.
Buy better pads. Stay away from ceramics.
Think about that.
Or Raybestos.
Or (name them).
Think about that.
Or Raybestos.
Or (name them).
Anyways, so I have Brembo pads I will be using. Still need new rotors because mine are totally screwed on the back side. Can you guys recommend the best place to buy centrics online? TIA.
One on the right for me
I had a really hard time finding any place that maintained a stock of centric pads. I made the switch to the two piece racing brake rotors about 10 years ago and have been very happy with them. I had a bad spell of trying some garbage after market pads before just paying OEM prices for the true brembo pads and not the knock off ones. However, I recently put on pads that...well I can't remember who made them as I've misplaced the invoice.
CAD Guy
+1 for centric rotors from me, been using them for years on several vehicles with no issues. I found that Rockauto is a good place to pick them up for decent prices and shipping speeds. Also try to at least get the e-coated ones, they tend to not rust very easily.
Latent car nut
Rockauto sells centric.
Lately, I've been buying the Raybestos coated rotors. They're cheap...and they're coated. Also on rockauto.
I wouldn't use those brembo pads if they're ceramic.
The closest pad to the factory set is probably EBC EBC greenstuff.
Stoptech SPORT or STREET are also both viable alternatives.
So...
If you cannot accept some level of brake dust:
So...
- Check if your pads are ceramic.
- If they are, place them in the trash.
- Buy something better.
- use ceramics
- accept your rotor pulsations
- keep your shame deep inside.
Latent car nut
I am using Centric Ctek on all cars and never had any problem with it. Pads is your personal choice weather you can deal with the dust and get good bite (OEM) or other high end ceramic pads (Akebono etc....). As far Pad goes please stay away from the Brembo Red pads its suck!!!
Just a piece of iron...well...kind of. The quality of the iron or the content of other metals may very between brands, products, and price points. I do "mostly" agree they should not really warp...it usually is more about uneven pad deposits. The price point differences will more than likely be more about visual appeal and how long they last. And see my previous note about what is wrong with ceramic pads?
I hate brake dust. I hate pulsing brakes. I have ceramics pads. I have no pulsing. Not sure what the issue here is.
I swap rotors every time I swap pads.
So as long as the rotors are cast properly and aren't pitted and they're properly machined - I'm good!
I guess if you plan to buy $200 rotors and then buy rotor-friendly pads and then re-use the rotor for 5 or 6 pad swaps....then expensive rotors make sense?
I live in the midwest, bruv.
The cars I don't daily drive are used on the track. So...either my rotors crack from track use...or they rust to death from winter use. Either way, they're 1 time use items.
If you have NOT gotten rotor pulsations with ceramics, you lucked out or you're using a fairly well made set of pads.
People have different priorities. I like my car to stop well. I like feedback from the pedal. And I like that deep deep torque feeling.
I avoid brake dust by simply not looking at my wheels.
It also rains here 9 days out of the week. The car gets dirty at the same rate at the wheels and I wash all of it when I wash it.
Even if it didn't rain...I prefer dirty wheels to a car that doesn't stop excessively well.
Some people prioritize clean wheels and long pad life over having a pad that stops well.
I guess my point is that you shouldn't be *surprised* if you get pulsing brakes as a result of your priority on clean wheels.
Just like I'm not surprised that my wheels are dirty because my car stops well.
Dirty pads stop better than clean ones in the same category, bruv. And they are less prone to rotor pulsations. In every single case.
SickSpeedTypeS (03-10-2024)
I've had pads like Akebono Street Performance, ACT, AXXIS, BOSCH, Wagner, AC DELCO, Raybestos, Centric, etc. All end up with the rotor getting warped fast from agressive driving or too quick before you can catch a bad caliper.
The initial bite is something all brakes should do well and that means dust too. I am more worried about stopping than looking OCD. Metals also squeal a bit on cold application, but not an annoying squeal.
Head a da Family
Stay away from those Brembo pads. They're clearly not anywhere near as good as the OEM pads just because they say Brembo on them. My main man & best friend from high school who ran an auto parts store for 25 years says the best pads for Hondas and Acuras are Akebono. I had them installed my last brake job and all I can say is WOW! Phenomenal stopping power and no dust.
2004 - 2006 6MT and all 2007-2008 Type-S have the same Brembo front brake parts.
2Morrow
05-11-2011 11:28 PM
aznboi2424
04-03-2011 07:35 PM
MyTL09
12-31-2010 06:23 PM
fabshopmiami
01-30-2010 12:13 AM
