Best Oil for an '05 TL after 140K miles
I was wondering whether to keep using conventional motor oil or switching to synthetic. I've had the car since day one and have always using conventional though after reading forum after forum, am left wondering whether to keep at it or switch. That being said, I appreciate suggestions for the best conventional stuff or whether to just switch. Thanks.
The following 2 users liked this post by LawnPro:
Iram Deum (09-16-2012),
JewelzEyes (04-18-2022)
the funny thing is;
any oil will do.
if you're changing the cars oil when the MID calls, then you can stick to any kind of oil; whether it be synthetic or conventional dino oil.
Most synthetics on the market are BLENDS.
so, what this means is....
you can use any kind of oil.
any oil will do.
Yep any good oil is fine. Use a premium filter and make sure the oil change is done correctly and you're good to go.
I've been using Valvoline synpower from walmart, and buy the Royal Purple filter on Amazon. I replace the plug gasket about once a year.
I use either Valvoline Synthetic with OEM oil filter, many other member had recommend Redline but none of the store near me carry Redline so the next best in line is Valvoline.
I like turtles
What ever is on sale....
Head a da Family
I use NAPA's own brand of 5W-20 synthetic which is Valvoline Synpower with their name on it, around $5.49 a quart. I also use NAPA's own brand oil filter, which is a WIX with their name on it, #51334, around $7 which I find keeps the oil cleanest longest. No need to spend $14 for an oil filter.
The Royal Purple filter is 12.55 shipped with Amazon Prime right now. Its made in the USA, which is good to support. Its well worth the peace of mind & price, especially if you 'want the best' for your TL or run long in-service oil cycles.
I use castrol GTX 5w30 (fall/winter) and 10w30 (spring/summer)
The J-series wasn't designed around synthetic. And it will actually burn synthetic, though I am sure some here will swear by synthetic.
I'm at 142k miles, yet to have any engine problems to date. So save you another $10. Just be sure to always keep up with your oil changes. I used to go 5,000 miles but I started to change mine every 3,000 because my driving habits fall under the "severe" category in the owners manual.
I also use purolator pure one filters. Stay away from OEM, since they switched to a different company. Avoid FRAM at all cost. Bosch is another good alternative.
Head a da Family
Just where the heck did you get all that malarkey from?
I've been using nothing but synthetic since my 1st oil change and after 135K hasn't burned a drop. In fact, Tony, the head mechanic at Acura of Manhattan in NYC said to ONLY use synthetic in this engine when he took the oil cap off at 90K and showed me how clean it was (and still is) in there.
As for Castrol, I'm sure it's good oil, but I'm still boycotting BP which Castrol is a division of.
It will actually burn synthetic? The J-Series wasn't designed around synthetic?
The key is to only drive 5-6k miles between changes.
It's annoying to hear people say they go 10-12k miles before a change.
It's probably fine to go that long but why push the oil that long?
first time Ive heard that a J-series burns oil, specifically synthetic. if it can burn synthetic, it will burn ANY oil. its not like the engine knows or can tell if it has synthetic or regular oil, but you might say that it knows the difference between the two.
justnspace (09-17-2012)
I knew I was gonna get burned (no pun intended) after my post. I got the info from two members of another forum who built their J motors. I will find the link when I get home tonight.
Such were the case, honda engineers would be easily replaced by any mechanic who knows how to build a motor.
If these motors "burned" synthetic oil, you would have no trouble finding links and discussions about it.
These guys are well known on the forums. I am new to this forum so I don't know if anyone built their J32 and stroked it. But the name Paul Smalser should ring a bell to at least a few on here. He is not your ordinary mechanic you find on the street. He's worked on several J engines and knows it inside and out.
I stopped listening to Honda engineers when they told me to change my automatic transmission every 60k miles. We all know those auto tranny need to be changed every 15-20k miles or else they are prone to failure. If the engineers are perfect then please explain the high failure rate of the transmissions. Explain why the 3rd Gear in the 6MT pops out using Honda fluid but not when using GM synchromesh or Amsoil MTF. I could argue with you all day but I honestly don't care. I am just here to help and inform anyone who is open to suggestions. If you don't believe me or whatever, then just take it with a grain of salt. I'm not here to misinform or mislead anyone. Just spreading what I have read and learned about these motors.
Here is the link. I normally do not listen to claims people make over the forum but Paul has proven himself with his engine builds and recommendations. The guy knows his stuff and people have even traveled from as far as Cali to North Virginia (where he lives) to get their engine built and swapped or even simple mechanical work. This man also made the brackets to make it possible to run RL BBK's on Accord/TL/TSX as well as adapting the m90 supercharger to the J series engines.
http://elitecm.net/forums/index.php?topic=1901.0
Notice he also mentioned he used an oil pressure gauge to test each of the oils.
Also, if anyone wants to use their synthetic blend, I mean 'full' synthetic oil then keep using it. Your engine won't blow up. I just don't think it's worth the extra $10 when I keep up with my oil changes and have not had any engine problems. No misfires, no CEL, nothing.
what kind of work they done still doesn't change the fact that a specific type of engine, in this case the J-series, would burn ONLY synthetic oil. that is just plain retarded.
sure, there are engines out there that do burn oil. but those would burn ANY oil in their crankcase, not just synthetic. its like saying water won't evaporate but purified water will.
just because they build engines doesn't make their word gospel. especially with the kind of proposition you are implying. I know people that have torn down and rebuilt 4G63 engines like it was nobody's business, both for street and track, but that doesn't make them an authority over common sense.
If an engine burns oil, it will burn oil. synthetic or otherwise. it doesnt know the difference between regular, synthetic blend or full synthetic.
Let me retract my statement. All oil is burned. For someone to say not a drop was burned is ludicrous. But synthetic burns more. I am in no way saying synthetic is inferior to conventional. Just on this specific engine, I don't know the exact words to explain it. But if you type in 'synthetic oil' in the search on v6 performance and drive accord forum and you will find several threads of complaints of owners losing one or more quarts of oil on synthetic. I myself used synthetic in the past and I would lose a quart and sometimes an additional half. So with all the complaints and my own experience, I decided to just stick to Dino oil and save the extra few bucks. I also change every 3k miles so synthetic would be a waste to me.
And I wonder how many of you actually clicked the link and read through the thread
Here is another link. Read post #91
http://www..net/forums/7th-generatio...you-use-3.html
From another member who runs a shop and built his J35a8 in his Accord. Him and Paul are the informative ones who post when people have technical issues.
I'm gonna leave it at this. I know how bad oil threads get.
125,000 miles on mostly M1 5w20 syn blend, one time on M1 0w40 full syn, and the last two changes on Honda 5w20 syn blend. Oil change intervals from 7500 to 10,000 miles. Never added oil between changes, never down more than 1/2 quart.
fyi i clicked through the thread and I still stand by my original statement.
if an engine burns oil, it will burn ANY oil. synthetic or otherwise. you are trying to throw us off by saying the J-series burns oil.
the threads you are linking are referring to built engines. not STOCK. you made a blanket statement that J-series burns synthetic oil:
I have not heard/read/seen any J-series burning just synthetic oil. if that were the case, people here would have mentioned it at the very least. stock J-series engines wont burn oil unless there is a problem. but they wont burn the oil simply because its synthetic.
you are referring to people working on BUILT engines, not STOCK engines. big difference. I've used synthetic from the first oil change and have not had to add oil in between intervals. a LOT of engines were NOT DESIGNED around synthetic oils. that doesn't mean they automatically burn synthetic oil.
