Best $100 mod/mods
Old Dec 12, 2010 | 08:39 AM
  #41
VQPower37's Avatar
change all the interior bulbs to white LEDs (not in the dashboard), probably will run you around 60 dollars
Old Dec 12, 2010 | 09:29 PM
  #42
blazinginder's Avatar
TL SL ML :)
Can somone provide me a list of LED part #s for the interior lights in a 3G TL Type-S (PM if possible)
Old Dec 12, 2010 | 09:43 PM
  #43
o4Komodo's Avatar
Rev High; Drive Happy
Driver/Passenger Door, Front Dome Light, Rear Dome Light, Driver/Passenger Vanity-Mirror, Trunk, License plate all take 194.
Old Dec 12, 2010 | 09:49 PM
  #44
I hate cars's Avatar
Originally Posted by mrlal8
Just because its the thickest bar does not automatically make it the most improved performance. OP depends if you have an auto or a manual. If you have an auto go with the comptech because it will matchup better with your auto front sway bar. If you plan on getting a type S front sway bar then you shud go with a progress rsb.
X2. The Progress bar especially in firm coupled with the stock 5at front swaybar will make the car too tail happy and it will actually handle worse than stock. Tail happy is no good on the street.
Old Dec 12, 2010 | 09:51 PM
  #45
Originally Posted by turtlecivic
Thank you for everybody with their opinions. I got the new navi disk already for my car. Is there a difference between Progress and Comptech RSB? Any suggestion where I could get the whole interior LED bulbs because most site are sold out.
22mm vs 24mm. Too thick on the rear and the car becomes tailhappy. It will feel like it handles great until you push the limit and it swaps ends on you. The 22mm Comptech should be perfect for the stock small 5at FSB. Overall handling balance will be better.
For the 6mt and especially the Type-S with it's larger and solid front swaybar, the Progress 24mm would be the better choice.
Old Dec 12, 2010 | 10:44 PM
  #46
SpiderX1016's Avatar
Which will make it more neutral on a 5AT, Type-S RSB or 22mm Comptech?
Old Dec 13, 2010 | 12:14 AM
  #47
That's a tough call. The 20mm Type-S RSB is matched to the 27mm FSB and with a little understeering safety built in. Couple it with the 5at's little 25mm hollow FSB it would definitely bring it toward neutral.
If it were me, I would do the 22mm. I've never run the 25/20mm combo but based on the 25/22 combo it's almost perfectly neutral with just a touch of oversteer in some situations. Either would work fine, I think it's a matter of whether you would prefer just a touch of understeer or oversteer.
Old Dec 13, 2010 | 01:37 AM
  #48
chairguru22's Avatar
Unregistered User
Best "cheap" mods: Tint, chrome door inlays, DRL/fog light swap, white LED license plate swap.
All of these tints except the tint should be way under $100.
Old Dec 13, 2010 | 06:19 PM
  #49
NOTSKERDD's Avatar
Shaved drivers side door handle, 12.00@dealer.....
Old Dec 14, 2010 | 04:35 PM
  #50
KiWiLiT43's Avatar
http://www.v-leds.com/
Old Dec 14, 2010 | 04:39 PM
  #51
dave_ramkumar's Avatar
2011 ZCP E92 M3!!
get tints , if you don't already or interior leds
Old Dec 14, 2010 | 04:48 PM
  #52
mrlal8's Avatar
no offense but i believe this is the most complete waste of 12 dollars i rather go to chipotle and buy 2 steak burritos lol
there is a reason why there is a key insert on the drivers side. It serves for emergency purposes. If you lose your remote or it comes off ur keychain then you can always use your key to open the car.
...i have a viper remote so im screwed if i dont have my remote but i still dont do the mod just incase i need to open the car
Old Dec 14, 2010 | 05:03 PM
  #53
07tl-s6spd's Avatar
Chapter Leader (Central New Jersey)
^^^if i lose my remote my key is tucked away inside so id be screwed anyway..lol
Old Dec 14, 2010 | 05:06 PM
  #54
mrlal8's Avatar
haha you have the switchblade...so lets say ur battery dies (very slight chance lmao)
Old Dec 14, 2010 | 05:10 PM
  #55
Slpr04UA6's Avatar
-------Tim-------
I don't agree with that at all! My key is in the remote, and if the remote is dead in an emergency, it would take a total of 2 seconds to pop that little cover off!
OP-The rear sway bar is one of the best bang for your buck, around $100!
Old Dec 14, 2010 | 05:25 PM
  #56
djflex167's Avatar
if you have a 3G Base TL A/T, what would be best, a 22mm comptech RSB with stock front? or Progress RSB with upgraded type s front fsb? thanks
Old Dec 14, 2010 | 05:27 PM
  #57
There's a lot of info on here about swaybars. I don't want to take this too far off topic. I would do the Type-S/24mm.
Old Dec 14, 2010 | 07:48 PM
  #58
turtlecivic's Avatar
Originally Posted by KiWiLiT43
I see so many... I know the bulbs size is 194... which ones do I get? Any recommendations? I see a lot of LED lights on ebay and some vendors have lifetime warranty... should I stay away from them?
Old Dec 14, 2010 | 10:24 PM
  #59
LaCostaRacer's Avatar
I can only comment on the Comptech bar. The handling is definitely improved and this was my 2nd mod (after tints). I have not had any issues with broken endlinks or torn out mounts like I did with my Maxima with some big bars installed as part of an Eibach Pro kit. I had rear bar problems by year #2 with the Maxima- a couple broken endlinks and a torn out passenger side mount.
The swaybar has been going strong for 4 years so I would think if I were to have problems, they would have happened by now. It sounds like the endlinks are the weak part for the TL and has a 40-$60 solution in some beefier links.
Old Dec 15, 2010 | 07:44 AM
  #60
SharksBreath's Avatar
BANNED
turtle, here is a list of ALL the bulb sizes for your car.
https://acurazine.com/forums/3g-tl-2004-2008-93/3g-acura-tl-bulb-sizes-list-3g-garage-g-077-a-691135/
i got every single one of my LED's from eBay, and saved a lot of money that way. i have not had a single problem with them whatsoever. i posted a complete line-up of the ones that i got, search my name and find my post...i don't know which thread i posted it in, i can't remember.
the only ones i got from v-leds were the license plate lights. and i only did this because they ARE nicer lights, and are more durable. the fact that we open and close our trunks often has a negative impact on LED's, and i found that the v-leds were better made.
Old Dec 15, 2010 | 11:16 AM
  #61
AtlM5's Avatar
+1 If my switchblade dies or I have to use the valet key (happened a few times) I need it. Yummyy chipotle!
Old Dec 15, 2010 | 11:49 AM
  #62
Steve5.9's Avatar
injured... injured bad
LOVE this thread! I'm doing most of these mods after exams are done this weekend. Goodluck OP!
Old Dec 15, 2010 | 01:30 PM
  #63
07TLTypeS420's Avatar
3.5L...enough said
Originally Posted by 08A-SPEC
curb feelers
+1 that's that Ol school stuff right there!!! LOL ahahahahaaaa
Old Dec 15, 2010 | 01:47 PM
  #64
Yonkers914's Avatar
04Tl
DEF. Tinted windows
Old Dec 15, 2010 | 02:54 PM
  #65
mrlal8's Avatar
i got the rsb installed 2 days ago
big ass difference...wow
didnt think it was guna do anything i was just going by what other people were telling me to do but its DEF worth it
Old Dec 15, 2010 | 07:38 PM
  #66
BukvaMan's Avatar
Lets say i found out the hard way . I tailed out and ended up with close to $9000 in damage. I dont think it improves handling that much at all, it actually adds confidence with nothing to back up, very unpredictable. It does feel better though but dont push it.
Old Dec 15, 2010 | 07:55 PM
  #67
Yep, that's the exact reason I tell people to match the front and rear bars otherwise you're going to be in for a surprise the first time you push the limit. The worst thing is that the car feels like it corners better so as you said you get more confidence to push it. Glad you were ok.
Old Dec 15, 2010 | 08:04 PM
  #68
Stepien20's Avatar
Originally Posted by Yonkers914
DEF. Tinted windows
+1
Old Dec 16, 2010 | 07:18 AM
  #69
csmeance's Avatar
Originally Posted by leedogg
imo that only applies on extreme turns at a point where the rsb will overwhelm your fsb when your car twists on a turn. Otherwise it will outperform the thinner rsb up to that point. Besides you can always use the soft setting and it will be similar to the comptech.
the comptech 22mm is fine for most people and the 24mm progress one is a bit scary as some members have ripped off the brackets on the rear-subframe and needed to reweld them on for the Progress, and as well they have had broken endlinks!
Comptech 22 hasn't had anything like that happen so my vote is for that, plus it's cheaper too!
Old Dec 16, 2010 | 08:07 AM
  #70
Slpr04UA6's Avatar
-------Tim-------
I don't agree with the Comptech not having any issues, I thought I read that most of the rear sway brackets that were ripped off were with the Comptech bar. ??
I have the progress with the Type-s FSB, and like IHC said, it is a good match...
Old Dec 16, 2010 | 08:28 AM
  #71
I'm trying not to turn this into a swaybar thread....
I just have to say there are other factors in the subframe ripping than just swaybar stiffness alone. Suspension travel and spring rate are two big factors. If your car is lowered on stiff springs and with a Type-S or stiffer FSB, chances are you're not going to break the mounts.
I've had no issues with the 24mm Progress bar on firm with my 28mm H&R front bar, a-specs, and Konis. However, the rear springs have been modified to be nearly twice as stiff as the stock a-spec rears for handling balance which I'm sure helps out taking stress off the rear bar.
Old Dec 16, 2010 | 08:12 PM
  #72
I just did a search and found no postings on the Comptech bar causing problems with endlinks or mounts but lots of hits on the Progress bar.
With stock springs and shocks assumed (since we're on a $100 budget here), I think the Comptech bar seems to be a good choice.
Old Dec 16, 2010 | 11:36 PM
  #73
edmontonoilers's Avatar
Get the interior lighting led mod with the license plate led. Best mod ever and its quite easy.
superbrightleds.com is the place to go.
https://acurazine.com/forums/3g-tl-2004-2008-93/those-want-led-interior-lighting-identical-oem-755183/
https://acurazine.com/forums/3g-tl-2004-2008-93/licence-plate-light-back-up-light-3g-garage-g-052-a-584870/
Old Dec 16, 2010 | 11:37 PM
  #74
mrlal8's Avatar
comptech rsb has caused many probs on tsxs
Old Dec 17, 2010 | 07:22 AM
  #75
Slpr04UA6's Avatar
-------Tim-------
I never said that is wasn't a good choice, but I did find one thread which seems to have a few members with this issue.
https://acurazine.com/forums/showthr...y+bar+problems
Old Dec 17, 2010 | 09:10 AM
  #76
chay823's Avatar
Mid Muffler delete!!! Best mod that I've done
Old Dec 17, 2010 | 10:06 PM
  #77
Looks like the one issue reported with the Comptech dealt with a broken passenger mount that also included polyurethane bushings along with the Comptech bar- after two years. Despite these issues Shalooby still thought the swaybar was the best mod he did in a later post in that thead.
I had polyurethane bushings on my Maxima too and I wouldn't rule those out as a factor in breaking mounts and endlinks. I have the stock rubber bushings and have no problems after 4 years.
Old Dec 23, 2010 | 01:09 AM
  #78
Confirm
I want to confirm if these fit for the whole interior bulbs because I was to buy it right the first time. I've read the bulb size garage. I just want a 2nd opinion. I'm going to buy these tomorrow. http://store.ijdmtoy.com/ProductDeta...U_C03&CartID=3.
Old Dec 23, 2010 | 09:30 AM
  #79
mrlal8's Avatar
dont think the rsb will mess with the mounts in TLs. Prob just endlink failures. I just got it installed a week or so ago. Amazing
Old Dec 23, 2010 | 09:33 AM
  #80
wantedTL/TS's Avatar
HID Nazi
DEF. Tinted windows
I prefer the fishbowl look!
