Belt fo Pulley
Belt fo Pulley
i have a ur crank pulley (stock diameter) just wondering what belt it uses. i understand the other pulley uses serpentine belt. i'm not too sure if it uses the same kind of belt or not?
AZ Community Team
Received 7,771 Likes
Same belt spec - OE or OE replacement. Gates is recommended but not required; GY Gatorback may not be optimal due to something with the design of the edge (iirc).
http://www.gatespowerpro.com/Comerge...TOKEN=39959544
http://www.gates.com/common/part_loc...m.cfm?id=S6037
Double, double check that belt fitment for your year/trim. Pretty sure all 3G TL are the same.
the stock diameter light pulley uses a GATES belt in the same size as stock
Gates has an edge that fits the UR pulley much better than other brands-
use it so you wont get noise
The Underdrive pulley uses a different belt size because the total length has changed
for correct part number call Josh at Excelerate - website www.excelerateperformance.com
AZ Community Team
As 01tl4tl mentioned Gates brand had a different edge that fits the UR pulley a little better, but you could re-use your OE belt.
