Beam Pattern
Old Jan 2, 2005 | 07:31 PM
xtremejujubee's Avatar
4th Gear
Beam Pattern
Does anyone else think that there TL has a wierd beam pattern on the ground. Mine don't light up the ground until you get maybe eight feet away from the ground. I'll put up pics if anyone may want to see this. Anyways I was just wondering if anyone else has the same problem! See ya everyone.......
My second post!!!!!!!!!!!!!!!!!!!!yea
Old Jan 2, 2005 | 07:35 PM
NFLblitze1's Avatar
Youse Gots Sacked
id like to see what the hell ur talking about...lol
Old Jan 2, 2005 | 07:47 PM
Hawhyen51's Avatar
I take it you're referring to the HIDs ... if you suspect it's out of whack take it back to the dealer for readjustment. You might use the search feature to see if anyone else has problem, if it is one. Some folks have noticed the left side is slightly lower than the right. It was probably done that way so it doesn't blind oncoming traffic. Check out this link: HID
Old Jan 2, 2005 | 08:00 PM
Bluenote's Avatar
Ex-Acura Service Manager
It's normal for the driver's side to be lower than the passenger side. When shining on a wall, the beams should look like this:
__/------
If it looks like that, leave 'em alone, they're fine.
Old Jan 2, 2005 | 08:03 PM
4th Gear
I ment to say they don't light up anything until like 8 feet away from the front of the car.....is that normal?
Old Jan 2, 2005 | 08:30 PM
SouthernBoy's Avatar
Registered Member
No, it's not normal for them not to "..light up anything until like 8 feet away from the front of the car".
Yes it is normal for them to produce less light "8 feet away from the front of the car".. actually more than 8 feet. The reason is because the TL uses a projector lens for its HID lamps and not a reflector.
Old Jan 3, 2005 | 12:04 AM
jbtcole's Avatar
The lighting on the TL is different from any car I've ever owned. The posts above are correct, but if you think it's a problem, I'd check with your dealer just to make sure.
Old Jan 3, 2005 | 12:13 AM
Teh Jatt's Avatar
The Oracle of Acurazine!
ok i'm just
Old Jan 3, 2005 | 02:14 AM
Lokius's Avatar
Silky Smooth
Try to get them re-adjusted by the dealer, they do cut a little low even stock from the factory, just remember with these HID's if you have them misdirected, you can really blind the hell out of oncoming traffic, so dont play with them yourself. You can try adding a HID foglight, which will help spread light out to the left and right of your car.
Old Jan 3, 2005 | 06:25 AM
mio's Avatar
mio
Police
check ur eyes... maybe u got something called "nyctalopia"? lol, kidding~
Old Jan 3, 2005 | 09:09 AM
Alan Barreuther's Avatar
Yeah! on my RHD British car they are set to dip the other way for the other s9ide of the road. That is the way it works!
Old Jan 3, 2005 | 10:27 AM
TLXLR8S's Avatar
TLover
use ur fogs. that will help for the front and sides of ur car.
Old Jan 3, 2005 | 10:58 AM
4th Gear
thanks everyone for your comments!!!!!! the reason i asked this is because on my previous car i never had that problem so i was just wondering......see ya
Old Jan 3, 2005 | 11:09 AM
Brewmaster's Avatar
I'm Baaack!
Finally - because they are projector lamps and do not use a reflector there is less "wash" from the lights .. they are somewhat focused and the light does not actually illuminate the ground directly infront of the car. The fogs help to fill in this void. What you have described is normal and not really an issue during night time driving (as hopefully you would have seen whatever is in the road long before it was 8 feet away, and if it crawled out in less than that you wouldn't have time to stop/avoid anyway)
Old Jan 3, 2005 | 04:56 PM
Road Rage's Avatar
Not a Blowhole
blacktsxwagon
Oct 27, 2015 10:12 PM
kev87a
Oct 18, 2015 02:03 AM
truonghthe
Oct 1, 2015 03:13 AM
rockyboy
Sep 29, 2015 12:05 AM
ceb
ILX
Sep 27, 2015 10:56 AM
