Basic knowledge newbe question..............
Old Dec 27, 2007 | 06:17 PM
RA122825's Avatar
Ok, be patient with me here........
Starting research to buy 04'+ TL 6 speed manual.
Question is.....In 04' was there a specific "sport" model or package offered on top of the base model?
In looking at much info online.....It looks as if any TLs delivered with a 6 speed man trans were equipped with a "sport" pkg of performance enhancements that the auto trans TL did not come with??????
Someone please slap me up side the head if this is way off, then set me straight if you would
Old Dec 27, 2007 | 06:22 PM
phee's Avatar
I got the Shifts
TL-S. you can do a wiki search for the acura TL and get all the info man. oh yea, put your flame suit on
Old Dec 27, 2007 | 06:23 PM
TSXACE's Avatar
No, you are correct Shifter7. The TL equipped with the 6sp manual tranny did come with stiffer suspension and Brembo brake calipers and pads, along with "High performance" summer tires. In my opinion though, they were crap tires
Old Dec 27, 2007 | 06:24 PM
ggesq's Avatar
Shifter7- welcome to the forums.
For MY 04, 05 & 06, there was only one type of TL. The Type-S was re-introduced in MY 07. For 04, 05 & 06, the base TL either came with Navi or not and auto or MT. The MT vehicles came w/ a limited slip differential, thicker rear sway bar, optional high performance tires and Brembo brake set up which really set it apart from the AT TL's for those respective years (IMHO).
The Type- S is a different animal.
Old Dec 27, 2007 | 06:26 PM
ggesq's Avatar
No need to put a flame suit on since we don't treat new members who ask legitimate questions in 3G like crap.
Old Dec 27, 2007 | 06:37 PM
RA122825's Avatar
Didn't think to use wiki, did get a few new details not known-
Ok turning my guts out, tell me what "3G" means......
Not afaid, I'm made of silicone so I don't burn anyway-
Old Dec 27, 2007 | 06:40 PM
ggesq's Avatar
3G= third generation TL or in the context which I used it in above- the 3GTL part of the forum.
Old Dec 27, 2007 | 06:42 PM
RA122825's Avatar
3G=Third Gen......took a minute to pull my head out
Old Dec 27, 2007 | 06:56 PM
RA122825's Avatar
Ok, so looks like 04'-05' 6spd created pretty much equal......
Was the 06' change to 60-40% a big leap or not so much?
How about the front Brembo 4 piston fronts, big leap?
And the ECM change for torque steer, Big leap?
Thanks so much for being good to me.....kinda makes me feel guilty-
Old Dec 27, 2007 | 06:57 PM
timmahh's Avatar
it's me, Alan Rickman.
As far as model info.. some places use confusing names, pretty common ones:
4DR BASE
4DR BASE NAVIGATION
4DR SPORT
4DR SPORT NAVIGATION
4DR SPORT NAGIVATION SUMMER TIRE
4DR SPORT SUMMER TIRE
which translates to
TL Auto
TL Auto w/ Nav
TL 6 Speed
TL 6 Speed w/ Nav
TL 6 Speed w/ Nav + High Perf. Tires
TL 6 Speed w/ High Perf. Tires
For changes
04 New 3G Model Introduced
05 Change to front seat bottoms [additional stitching to help with wear?]
05 New Passenger Airbag light above haz. lights
06 New ECU programming for torque steer control
06 Tire Pressure Monitoring Standard
i might be wrong on the changes, but I think that's about right..
Old Dec 27, 2007 | 07:08 PM
shubysingh's Avatar
wat bout the a spec pakg, isnt dat like a sport pakg?
Old Dec 27, 2007 | 07:09 PM
RA122825's Avatar
4DR BASE
4DR BASE NAVIGATION
4DR SPORT
which translates to
TL Auto
TL Auto w/ Nav
TL 6 Speed
TL 6 Speed w/ Nav
For changes
Yes, very close according to wiki anyway-
Old Dec 27, 2007 | 07:15 PM
RA122825's Avatar
Anyone got an opinion????
On the 06' changes-
Change to 60-40% a big leap or not so much?
Old Dec 27, 2007 | 09:28 PM
Will Y.'s Avatar
Registered but harmless
On the 06' changes-...
Welcome to AZ.
The TPMS (tire pressure monitoring system) for '06+ is a worthy addition. I would prefer the '06 over the '05 for that reason. However, the running changes are really pretty minor and not a big leap.
There was also a "factory" or dealer installed "A-spec option" for the '04-'06: body trim pieces (rocker panels, front lip, trunk spoiler) plus 18" wheels; IDK if there were different shocks used for the A-spec package from the factory. The 18" wheels are nice though.
The only big leap on the 3G is the TL-S version starting in '07, which has the 3.5 from the RL dropped in place of the normal 3.2. The suspension on the regular TL from '07+ was softened up just a tad while the TL-S received a stiffer suspension.
Old Dec 27, 2007 | 10:24 PM
Bearcat94's Avatar
AZ Community Team
The "leap" in the '04 - '06 years was between the AT and the MT. The cumulative gains (MT + Sway Bar + Brembos) is a pretty good jump over the same model year AT.
I don't know if it's as much of a gap as the '07 Base to the '07 TL-S 6MT, given the add'l TL-S HP.
BTW - thats stock vs stock. Mod or A-Spec the AT and you start closing that gap.
Old Dec 28, 2007 | 01:11 AM
01tl4tl's Avatar
The Brembos start to give the car realistic stopping power for its weight.
There are excellent aftermarket replacement rotors and pads for the Brembos.
Brembos are 4 piston calipers instead of 1 piston calipers- requires more expensive replacement parts as well- but worth it.
Some of us with gen2, 2nd generation or 99-03 TL, convert the fronts to a 2 piston caliper from the old Legend car of the mid 90s
The TL got bigger faster and heavier without a brake upgrade until Brembos, the rest of the models are still on the junk single piston!
Old Dec 28, 2007 | 10:30 AM
Tripnbeats's Avatar
the sport package had different suspension, its stick, brembos and motor mounts were made to be abused. everything else was the same.
Old Dec 28, 2007 | 11:30 AM
bluffcityTL's Avatar
Where are the Lunch Trays
Hope all the info above helps.
Happy Shopping and welcome to AZine.
Old Dec 28, 2007 | 01:53 PM
RA122825's Avatar
Thanks all!!!
Between yall and wiki think I am sufficiently enlightened to do some serious shopping now.
Looking forward to a G3 TL and kickin it with the Acurazine community-
Thanks again, Skip
Old Dec 28, 2007 | 07:09 PM
Glad to have you on the site!
Old Dec 28, 2007 | 07:21 PM
Aman's Avatar
Your Friendly Canadian
Thanks all!!!
Thanks again, Skip
3G...memorize that...
congrats on the purchase (whenever you make one) and youll find this site quite useful.
IBankMouse
Jun 13, 2020 12:53 PM
ITSJESTER
17
Dec 6, 2018 02:29 AM
Oakroadsteve
Oct 28, 2015 10:28 PM
MilanoRedDashR
Oct 8, 2015 10:30 AM
0opie
Sep 22, 2015 04:15 PM
