Base TL - Footwell Ambient Light Mod?
Over Caffeinated
Yeah, I'm slow, but I just figured out that type-S models have ambient lights in the footwells.
Well, I want my base TL to have purdy blue ones.
Anyone done a mod like this? Suggestions or pitfalls?
Steve
Steve
some have done this with led strips and CCFL's, I believe they tap into the lights in the center console compartment.
Over Caffeinated
Steve
Received 6,470 Likes
Steve,
I had this done in my Type S, so I put in red lighting. I have this done both in the front and back of the Type S. I used 8" LED's, but I had the install done by a local custom car stereo dealership here in Kansas City. This cost me $200 total (including installation). I think they are wired into the fuse box and they turn on when I turn on the headlights.
Here are some pictures...you'll see I've also got red door lighting that I switched out myself along with the illuminated red door sills.
Front seating-passenger side...
![Name: 100_3947.jpg
Size: 32.4 KB](https://acurazine.com/forums/attachments/3g-tl-2004-2008-93/54635d1501300322-base-tl-footwell-ambient-light-mod-100_3947.jpg)
Rear seats-these rear LED's are mounted on the kick plate below the back seat-not under the front seats (where they could more easily be kicked and knocked out).
![Name: 100_3948.jpg
Size: 29.1 KB](https://acurazine.com/forums/attachments/3g-tl-2004-2008-93/54636d1501300322-base-tl-footwell-ambient-light-mod-100_3948.jpg)
Here is both of the front underdash lighting....
![Name: 100_3888.jpg
Size: 25.5 KB](https://acurazine.com/forums/attachments/3g-tl-2004-2008-93/54637d1501300322-base-tl-footwell-ambient-light-mod-100_3888.jpg)
![Name: 100_3950.jpg
Size: 35.5 KB](https://acurazine.com/forums/attachments/3g-tl-2004-2008-93/54638d1501300322-base-tl-footwell-ambient-light-mod-100_3950.jpg)
Here is a reflective shot of the driver's side, with the red LED's reflecting on the Dead Pedal with the Type S logo on it.
![Name: 100_3952.jpg
Size: 27.8 KB](https://acurazine.com/forums/attachments/3g-tl-2004-2008-93/54639d1501300322-base-tl-footwell-ambient-light-mod-100_3952.jpg)
tl_from_hell (03-05-2012)
Over Caffeinated
Steven B. - wow, that looks really nice ;-) When you say "8 inch LEDs" I assume you mean an 8" strip of LEDs? Can you tell me how many LEDs are in the 8" strip? I don't want to "over bling" (a technical term) when I do mine.
Thanks for the info!
Steve
Steve
I tapped into the glovebox light on the right side and the trunk release light on the left side. I used a strip of 4 leds on each side. I had to put 5 layers of blue painters tape over mine because they were way too bright.
Over Caffeinated
Thanks!
Steve
Steve, you are correct-they are 8" strips. But I'm not sure how many LED's are in there. One of the pictures show the LED's on the front passenger side. I'm not sure if that will show you what you are looking for, but give it a try. Actually, they also came in 10" strips, but the store that installed them said that they are VERY bright, so I stuck with the 8" strips. I didn't want to "over bling" as well !!!
Over Caffeinated
Steve
You're welcome Steve. Be sure to post pictures when you get them installed.
Over Caffeinated
Still waiting on my blue LEDs... in the mean time, I tapped the center console light circuit and pulled wires for the left and right front foot wells as well as for the top center console (arm rest). I did this while swapping out my heater switch lights for LEDs.
More once I get my LEDs.
Steve
Steve
Took my 07 TLS to dealer for my last oil change, when I got home, the exterior lights and beep weren't working when I enabled the alarm. Also noticed my navigation and radio lighting were very dim; I could hardly see the buttons.
So I took it back, they corrected the alarm issue, but didn't fix the interior lighting. The Service Order states:
"found fuse blown under hood fuse box, replaced fuse, blew again, installed breaker into fuse slot, believe tampering with fuse may have corrected problem".
Nav lighting & radio are still very dim, red footwells are out, but I still have the lighting in the center ceiling (above rear view mirror).
I bought the car used (CPO), and the Service writer is saying the fuse box probably isn't covered. Replacing the fuse box could run $450-$500.
I'm taking in next Thursday for another oil change, they are going check again.
Could it be specific fuses that are affecting the interior Nav/Radio Lighting, or the box itself?
How much do they charge you for oil changes, like at least $200? I have a friend who is a girl who takes her 08 TL in for oil changes and $200 is about the MINIMUM they charge her (they probably change cabin and other check ups).
Oil only costs $30-$40. Filter only costs $10.
That's a total of $50. The rest you do yourself. Saving yourself well over $100 nearly $200 already.
And if you are using a true synthetic, there is no need to take the car in at 5,000-5,500 miles. You can run the car 8,000-10,000 miles on a true synthetic before changing for new oil. If you are following the MID and taking your car in to get serviced every time the MID comes up that means you are spending at least $200 every ~5,000 miles.
Now that's getting raped by the stealership
rockyboy
12-06-2022 02:29 PM
TLDude876
12-28-2016 03:18 PM
handsom-hustla
11-13-2015 05:04 PM
sockr1
10-01-2015 01:31 AM
