Baking the Headlights
Old 02-23-2013, 10:18 AM
  #41
Chad05TL's Avatar
This is my 2005 headlights. I probably will not change my current TLS headlights. But I would if I could find some authentic Halo's like a BMW. Those are not like the typical halo's I see aftermarket. I need to polish the inside of my headlights on my 08's because the clear piece got slightly discolored from heat. So, I was using my 05 headlights as an experimental try to see if I could get it open. If so, then I will proceed to the 08's. As far as heat is concerned on the 08's, I am only running 6v through the DRL bulbs but appearantly that's still too much. So I bought a high power variable resistor to choak it back even more. The VR will work out easily since it uses connectors I already have in place. I think my 08 DRL were slightly too bright even with running at 6v, so if I treat brightness in porportion to voltage, then I will try to cut back the voltage to 4v. Maybe 4.5.
Anyway, as far as these 05 headlights, I don't know what I want to do with them. I might paint them for someone or just sell them after I clean them up. I do not plan on putting any clear coat on the plastic. Nor would I sand the plastic. These 05's are not that bad.
Old 02-25-2013, 03:13 AM
  #42
RoadxRage's Avatar
It's not that difficult. Bake for 20 minutes at 200 degrees. We pulled my headlights apart by hand, so it shouldn't be too bad. Once you have the headlights modded, put back together. I highly recommend you getting more Butyl from the auto parts store. That way, you'll be assured of no condensation once you put the lights back together. We baked them once again (same time and temp), to insure a tight fit.
Best of luck-it's well worth it....
2011 National AcuraZine Meet-Kansas City-June 12, 2011-Details Here!
SELL ME YOUR HEAD LIGHTS?
PRICE $$$ ???
Old 02-25-2013, 06:44 AM
  #43
rockstar143's Avatar
Received 19,926 Likes on 14,464 Posts
I can promise you that Steven's headlights are likely not for sale!
Old 02-25-2013, 07:04 PM
  #44
Steven Bell's Avatar
Received 6,470 Likes on 5,162 Posts
J is right-sorry RoadX.
They're not that difficult to do.....
Old 02-25-2013, 07:45 PM
  #45
RoadxRage's Avatar
[quote=Steven Bell;14339452]J is right-sorry RoadX.
Do them for me and i will pay you!
Old 02-25-2013, 09:36 PM
  #46
Chad05TL's Avatar
I posted a video, whatelse do you want. haha
Old 02-26-2013, 12:17 AM
  #47
paperboy42190's Avatar
Received 1,162 Likes on 847 Posts
its funny how you said "remove all that bullshit inside" lol
SharksBreath (02-26-2013)
Old 02-26-2013, 12:45 AM
  #48
5th Gear
Ankitito9's Avatar
Good job with the video! I've been meaning to clear out my headlights for a few months now, and your video definitely helps to visualize how to go about it.
Old 03-18-2013, 09:46 PM
  #49
Chad05TL's Avatar
Turns out there is no heat spot or oxidation or burning from heat. I opened my headlights yesterday and it was just a smeary residue. Not sure what caused it other than the bottoms of the headlights were not sealed. But it is now! .
Btw, I my sell these new lenses I bought because I didn't realize it but the TLS lenses are almost clear as the have a greatly reduced fresal effect than that of an 05 TL. But these other lenses have a notch on the side.Whereas my TLS lenses do not. So I want to make sure they didn't sell me the wrong thi.g before I try to resell. Gottom from TRS.
hashbrown
02-18-2022 11:20 AM
Mr.Tea
10-02-2015 10:32 PM
MilanoRedDashR
09-27-2015 10:15 PM
h22lude
09-27-2015 06:22 PM
AmplifiedDetails
09-24-2015 02:55 PM
Quick Reply: Baking the Headlights
