Bad Rotation Or Alignment Problem
Yesterday, I took my TL into Firestone to have the tires balanced and rotated (lifetime balance and rotation for $55). While driving the car today, I noticed the car is pulling slightly to the left. Should I take it back to have them inspect or rebalance? Or, is this a alignment issue? I didn't have this problem prior to this.
WDP Director of R & D
Take it to the dealer and let them figure it out on their dollar... IE warranty.
ABP Auditor
Rotate the front tires left to right. If it pulls in the other direction, one of the two front tires has a "pull". Now rotate one from front to rear until you determine which tire it is that is causing the pull.
If you rotate the front tires left to right and it still pulls in the same direction as it did before, it's an alignment issue. Have you hit any potholes lately (how can you avoid them, right?).
Zonian22
11-14-2015 01:20 PM
Zonian22
09-02-2015 08:19 AM
