Backup Sonar
Old Nov 23, 2003 | 01:08 AM
Jss1's Avatar
Backup Sonar
This option works very well. When you put the car in reverse it beeps for a second to test the sensors and let you know all is well and that they are all are working. The two on the back emit a different sound from the two on the side so you can fairly easily judge where the danger is. It also doesn't look as bad as it does in pictures and the colour match seems dead on. Great for parking i you are in a tight space. I wouldn't mind putting them on the front also.
The side molding looks pretty good also and everything blends in pretty well imo.
Old Nov 23, 2003 | 07:58 AM
EmuMessenger's Avatar
Pic's?
Old Nov 23, 2003 | 10:02 AM
Jss1's Avatar
Originally posted by EmuMessenger
Pic's?
The weather here is lousy. I am going to try and get the windows tinted later this week or next and I will get some pics when the wether allows. I am really starting to like the Desert Mist, even though it wasn't my first choice, so does everyone else it seems.
Old Nov 23, 2003 | 10:14 AM
erikmoeser's Avatar
Is backup sonar a factory option or dealer installed? I don't recall seeing that anywhere,
Old Nov 23, 2003 | 11:52 AM
Jss1's Avatar
Its dealer installed. Another interesting feature is all 4 modules operate independently. The back two have a low pitch and the side two have a high pitch. If you are backing at an angle both go off at the same time and you can tell whether you are going to hit from the back, side or somewhere in between. I love it.
Old Nov 23, 2003 | 01:03 PM
04SSMTLCanada's Avatar
Congratulations on the new car! Did you decide what level you are going to tint it?
Old Nov 23, 2003 | 01:12 PM
erikmoeser's Avatar
Does the Sonar warn progressively? I usually am aware that I am real close when backing in that type situation so I would like to be able to differentiate between being 12 inches away and say 6 inches or closer. Can it be adjusted? I would be happy if it was on or off at a distance like 6 inches.
Old Nov 23, 2003 | 02:08 PM
RJC RSX's Avatar
sonar is only underwater..
Old Nov 23, 2003 | 02:57 PM
Jss1's Avatar
Thats exactly what I told the dealer. He said it was the same technology. As long as it works I'm happy
Old Nov 23, 2003 | 03:10 PM
Jss1's Avatar
Yes it is progressive for all 4 sensors independently. No adjustment. This is what the manual says:
Sound corner sensors center sensors
slow beep within 2 ft within 6 ft
quick beep 1.5 ft 4 ft
continuous 1.0 ft 2 ft
I can't get the format right but you get the idea I hope.
Old Nov 23, 2003 | 09:08 PM
erikmoeser's Avatar
I suppose then when the tone is solid you can judge backing up another 1/2 foot or so. If it would be solid from one to two feet and turn off altogether at 11.99 inches :-) that would be great. Tone goes off and you know you have a foot to go.
Old Nov 23, 2003 | 09:28 PM
bklynTL's Avatar
can you disable the system ( by using a button or switch ) ?
Old Nov 23, 2003 | 10:39 PM
tesla's Avatar
What is the cost of this option?
Old Nov 23, 2003 | 10:58 PM
NOX 3.2's Avatar
TL-SHAWD 6MT Rocks!
I don't want to spend $600 (or whatever they charge) for the dealer option that only beeps.
I rather have the voice type, which goes natural with the NAV+Voice command feature of the new TL.
Plus it's a lot cheaper = $200
here are some links I've collected so far:
Reversing Aid with VDI (voice distance indicator) module:
http://www.tailgauge.com/model_a.htm $189 + S&H
http://www.poronusa.com/index1.htm
http://www.autoaccessoriesrusfl.com/carreversing.htm
http://www.car-reversing-systems.co.uk/main.htm
http://amos.catalogcity.com/cc.class...73456244-16117
or digital readout
http://www14.brinkster.com/parkings/sensors.htm
Beep
http://www.gdpsensor.com/
Rearview camera and other devices...
http://www.enjoythedrive.com/content/?id=30884
& it seems people don't like the ACURA version anyway...
http://www.acura-tl.com/forum/archiv...c/63823-1.html
bymotion
Nov 18, 2015 11:28 AM
navtool.com
Nov 16, 2015 08:03 PM
dirleton
Sep 28, 2015 07:05 AM
95oRANGEcRUSH
Sep 25, 2015 12:50 PM
Sep 17, 2015 09:01 PM
