Back seat lights
Old Aug 1, 2013 | 06:08 PM
Devin Maxwell's Avatar
Cool Back seat lights
I'm trying to take out my back seat lights to put in my LED lights but they won't come out. I can't find a video on how to take them out. Please help
Old Aug 2, 2013 | 08:27 AM
Undying Dreams's Avatar
The ones above the seat? Stick a butter knife in between them and pry from side to side, they pop out quite easily.
Old Aug 2, 2013 | 11:03 AM
hgigh's Avatar
I used a small flathead screwdriver and a microfiber cloth to prevent scratching the plastic.
But as Undying Dreams said get them from the hinge side, not the side that you push to turn it on.
Old Aug 2, 2013 | 11:08 AM
Oh and DISCONNECT the battery!!
I didn't and ended up blowing the fuse to work my keyfob and interior lights.
Plug in all your LED's, if they don't light up, disconnect battery again and flip the LED's, then reconnect the battery.
Old Aug 2, 2013 | 11:32 AM
Nick216's Avatar
The Boss
For some reason I thought Op was taking out his entire back seat for led strips. and I was like WTF !?!
Old Aug 2, 2013 | 11:39 AM
hgigh's Avatar
OOPS. I did not do this. I was turning the things on and off, flipping the bulbs making sure the LEDs would light.
Guess I got lucky.
Old Aug 2, 2013 | 11:54 AM
Lucky indeed!
Old Aug 2, 2013 | 12:51 PM
JTS97Z28's Avatar
Don't worry about disconnecting your battery to swap bulbs. IMO not needed and have never once blew a fuse. Just yank the bulb out its simple. I guess if you can't get it with your fingers just pry it out like others have said above.
It doesn't hurt to disconnect the battery, but it's too much work when you simply don't need to, or if you must just flip the switch at the front overhead console to off. Then if you disconnect the battery you gotta put in the radio and nav codes, and your trip odometer resets. Just turn the interior light switch to off if your worried about it and that's just as good.
Old Aug 3, 2013 | 03:36 AM
SmoothCrimnl's Avatar
flat head screwdriver in the middle slit and you should see it pop off. These were not hard to pull off but if you are replacing all your bulbs the best advice I received in the past was to use some scotch tape, wrap it around the bulb, and pull the tape and bulb. This made pulling all my bulbs a cinch. I replaced all my bulbs in my car including the trunk which I found to be a pain including the vanity bulbs for the mirrors.
Old Aug 3, 2013 | 12:46 PM
pandemictl's Avatar
flat head screw driver and like stated before just pry don't prey to hard if u feel u are stop u might break something
Old Aug 5, 2013 | 09:06 PM
mvp2765's Avatar
A tiny flat head screw driver. Don't have to disconnect the battery. Just make sure that they're off when plugging in the new LED's
Feb 25, 2020 09:57 AM
d.lim
Sep 15, 2015 08:54 PM
Phambam12
Sep 6, 2015 06:57 PM
iRaw
ILX
Sep 5, 2015 12:10 AM
