B12 service. part numbers?
I called the local acura dealer and of course they want like $400 dollars to do this, obviously I am not going to spend that because that ridiculous. So I searched on here for the parts I needed but cannot find the part numbers, when I go on acura website to order filter it says dust filter is $101 and there are like eighteen other filters. http://estore.honda.com/acura/parts/...-5at&dl=251411 what filters do I need from this site, also I will be ordering the serpentine belt to change while I am at it. Also I am at about 82K. Thanks
Early Shifter
If your drive belt isn't squeaking/glazed/cracking I'd leave it be until your 105K service.
B12 is a rotation and oil change, right? In that case all you need is an oil filter. A cabin filter wouldn't hurt either, I suppose. Especially if it hasn't been done before.
3G TL/2G MDX Owner
B= glorified oil change with inspections, 1=tire rotation, 2=engine and cabin filter replacement
might be easier to buy filters from parts dept at dealer...if they have coupons...even better. i got the cabin filter for like $22 from my dealer after coupon discount. i dont' need the endgine filter (i have a CAI). just a thought.
your car may code B12, but you can always just tell them do an oil change and a tire rotation should run you $70. go to parts counter...buy the filters (should be between $40-50 for both filters. now you just saved yourself $280. then go buy more toys for car witht he rest.
My 07 Acura TLS just called for the B12 service. I gave about 53K miles. I've been having my mechanic do all my services for the past 2 years, since the dealer became unaffordable. Anyone have an idea what should be done with the B12 service at 50,000 mi.5, other than changing the oil, cabin filter & rotating tires? Also, I hear a squeaky noise that sounds like crickets when car is running. Any help is appreciated. Thanks
3G TL/2G MDX Owner
your crickets....have the dealer check them for you. there is a TSB out for crickets near the TB area (front passenger side of the engine bay).
