B12
what does serice due b12 mean??....sorry only had car for 3 months
Replace engine oil and oil filter Rotate tires Replace air cleaner element( Engine) Replace dust and pollen filter( Cabin filter) Check parking brake adjustment -Fuel lines and connectionsInspect these items: -Front and rear brakes -Brake hoses and line (including ABS) -Tie rod ends, steering gear box, and boots -Suspension components -Driveshaft boots -All fluid levels and condition of fluids -Exhaust system -Drive belt Scroll down to the last page http://techinfo.honda.com/rjanisis/p...707O00272A.pdf |
^Yep, a bunch of checks, but most important that needs to be done is the oil change, tire rotation, and filters change (cabin, engine)
just a suggestion: check out the owner's manual-that is if the previous owner left it with the car. it has lots of great info.
Originally Posted by Anthrakítes
(Post 13760336)
Here's a link to the owner's manuals, if you don't have one:
https://acurazine.com/forums/3g-tl-2004-2008-93/j-020-3g-acura-tl-owners-manual-navi-manual-warranty-booklet-pdfs-851625/ |
thanks!! think its oil it says 15% ..... could i jus add?.monly been 3 months
You do not want to just add. Just do the whole shebang.
The filter is the main reason why we even do a oil change in a short time... not the oil. Buy a "oil change kit" from like Advance Auto Parts for roughly $30 or buy a RP filter and your preferred oil. If you don't feel comfortable in doing your own, buy the oil, and pay a trusted mechanic to put it in for you for like $10-15. |
(Post 13760336)
Replace engine oil and oil filter Rotate tires Replace air cleaner element( Engine) Replace dust and pollen filter( Cabin filter) Check parking brake adjustment -Fuel lines and connectionsInspect these items: -Front and rear brakes -Brake hoses and line (including ABS) -Tie rod ends, steering gear box, and boots -Suspension components -Driveshaft boots -All fluid levels and condition of fluids -Exhaust system -Drive belt Scroll down to the last page http://techinfo.honda.com/rjanisis/p...707O00272A.pdf Nice! Where in SC? <- Chucktown. |
nice timing. this just popped up on my dash too.
also got a tighten gas cap warning? wtf is that? It was plenty tight. ill go do some searching ;) |
Originally Posted by Westside_TL
(Post 13760483)
@LoveMyTL-S Thanks! @Guiltyox I am from Myrtle Beach :tgif: |
