B Service Due
B Service Due
is b and b1 service the same? nevermind did the search
mainly the b or b1 service requires oil change/inspections but why does the message come on when my mid is showing me that i have 15%...that i know that the oil change is due soon.
also a DIY oil change should cost me roughly $40 bucks, but a local oil shop is charging $42.98 plus tax for synthetic oil change. i also called them and they can use 5w20 mobil or castrol my choice but if i use the shops mobil oil filter they will charge $10 extra...but if i bring in my own they will knock off a few dollars....hm...what should I do?
this includes lube chassis (where applicable), check tire pressure, check fluid levels, check wiper blades, and check belts/hoses.
bearcat if you are reading this calm down
I was in for an A1 service (oil change and tire rotation). My dealer did an oil change and they actually topped off the other fluids and checked everything else as well. They said I didn't need a tire rotation since they were wearing evenly. Cost was about $45 for the oil change and I also had my state inspection and emissions done at the same time. Took about an hour.
So if you want to save time and energy your dealer may be a great option.
