"B" Service
"B" Service
Apologies up front - I tried searching and came up blank. Probably operator error, so bear with me.
Are the various service codes listed somewhere on this site? B service just popped up today on my MID.
thanks,
gurney
thanks,
gurney
From the Acura Owner Link Website:
Maintenance Minder B Scheduled Maintenance
Recommended service for your 2006 Acura TL:
Replace engine oil and oil filter
Rotate tires
Inspect front and rear brakes
Check parking brake adjustment
Visually inspect tie rod ends, steering gear box, and boots
Visually inspect suspension components
Visually inspect driveshaft boots
Visually inspect brake hoses and line (including ABS)
Visually inspect all fluid levels and condition of fluids
Visually inspect exhaust system#
Visually inspect fuel lines and connections#
Rotate tires
Check owner's manual...
Originally Posted by gurneyeagle
Apologies up front - I tried searching ....
OK, so I admit I checked this forum for the "B" service info first when my TL's "B" service reminder popped up the day before yesterday. :wink:
Thanks, dbett.
Originally Posted by Will Y.
Hey gurneyeagle, aren't you one of those over-40 geezers (like me) who used to read a car's owner's manual before the internet was even invented??
Thanks, dbett.
Thanks, dbett.
Will, you're correct I do read the manual. I just didn't have a chance this morning. It came up on the drive in (5:00 am), and I didn't get the chance to pull out the manual. I thought that the different service levels might be listed on the site. Thanks for the reply. I was just trying to save a little time - lazy me.
From what is listed, I'll just reset the MID. I change my oil every 6K miles with Mobil 1 and rotate the tires at the same time.
gurney
Car determines service time
Originally Posted by Riu
Is there a set milage where B service comes up?
