auto vs manual suspensions
Old Jun 14, 2004 | 04:00 PM
KCTL04's Avatar
8th Gear
What are the differences between the suspensions on the automatic transmission cars and the 6spd manuals?
I see there are heavier anti-sway bars. Are they interchangable? I have the auto - does anyone know if I can bolt on the heavier manual tranny bars?
Are there any differences in the shocks or springs?
Old Jun 14, 2004 | 04:06 PM
Aegir's Avatar
Powered by Guinness
Front springs (due to 5AT weight?), knuckles (brake mounts?), sway bars, recommended tire pressures. I think that's it as far as suspension. Bars should be interchangeable and an easy swap - just bars and bushings.
Old Jun 14, 2004 | 08:11 PM
pettydw's Avatar
You need to be careful in that the 6MT swaybars are optimized for the LSD setup, which affects front to rear weight transfer during cornering. The 6MT & 5AT traction control systems likely have different calibrations as well. In other words, if you stuff your modified car into a ditch, Acura will not be liable. The different tire pressures between the models also affect understeer/oversteer characteristics.
Old Jun 14, 2004 | 08:27 PM
Aegir's Avatar
Powered by Guinness
How does the LSD affect front to rear weight transfer during cornering? How would the sway bars affect the traction control system?
Old Jun 14, 2004 | 08:53 PM
al900rr's Avatar
I think the MT have the bigger brakes.
oyayjoe
Jan 1, 2019 10:17 PM
Zonian22
Nov 14, 2015 01:20 PM
mugen_kid
Nov 13, 2015 10:38 PM
HydrasunGQ
Sep 14, 2015 10:14 PM
asahrts
Sep 4, 2015 05:55 PM
