Auto transmission fluid can fill up thru dipstick?
LIST/RAMEN/WING MAHSTA 짱
Answer: YES.
Recommended? NO.
Here's a link to the proper way to do it: https://acurazine.com/forums/3g-tl-2004-2008-93/rr-journals-atf-drain-refill-3g-garage-c-012-a-556044/
Recommended? NO.
Link to 3G TL Service Department: https://acurazine.com/forums/3g-tl-2004-2008-93/3g-tl-service-department-aka-garage-questions-answers-check-here-first-553557/
Link to 3G TL Service Department: https://acurazine.com/forums/showthread.php?t=553557
my car is almost 9 years old
and i am pretty sure my fill bolt hasn't been touched for at least 5 years. really hard to reach, not to mention getting it out?
adding to dipstick no good? can you explain why?
and i do need to remove my splash shield to get the drain bolt right?
thx brother
I filled mine through the dip stick.
I just took a long skinny funnel and taped a straw to the end of it.
Make sure everything is squeaky clean, as always.
why not?
thx brother
thx brother
A breaker bar and long extension makes the fill nut a straight forward task to remove. Use a funnel with a long tube extension to fill up and you're good.
Dogmatic Dinosaur
I do it, but my car has the oil jet mod, which uses the drain hole.
I built a PVC funnel that uses a McDonalds or Chick-fil-a straw. Total PITA. Use the regular one, if you can.
mada51589
05-03-2022 08:54 PM
