AP2 S2000 vs 135i 6MT
On my home tonight, had a clean 65-100 run against a 1st gen 135i 6MT.
We first lined up in 3rd and I did the honking. Results? He pulled about 2 cars from me and shut down. Not exactly a close race, but I think I did decently with a slipping clutch and a full tank of gas.
Throw on a mild tune and I'd be done for
You did all right Tyler, considering they trap 103-105. I can't remember, are you stock?
And regarding the turns, they'd still be close. Both cars slalom in the low 70's.
My car is relatively stock, just an intake & exhaust.
Mods are:
Intake
Megan exhaust
F&F T2 Coilovers
Enkei RPF1 17x8 & 17x9 w/ Ventus V12
Here's how she sits today:
Let me know how you like the Q300 exhaust - I swear my current exhaust system has had a small detriment on my hearing
Maybe adding a resonator will help - putting the top down always drowns out the noise
I saved the specs for that car. That is what I want to build one day. Corner speed ftw!
We need to see vids of your car on Laguna! Any POV's?
Time Attack S2000
Engine
Hondata Intake Gasket
Spoon Head Gasket + 0.3
AEM EMS 1052U
Brian Crower Stage 2 Cams
Cylinder Sleeves
Custom PB Intake with HKS Filter
Custom PB Heat Shield
Custom PB Intake Headlight
Custom 70mm Headerback Single Exhaust
J's SPL 4-2-1 Header + Thermal Wrap Cool-It
S90 68mm Throttle Body
Oil Catch Can
Oil Pan buffles
Brail Battery (2.1kg)
Modifry Temp Fix
Suspension
Tein Monoflex with EDFC
Powerflex Bushings
Exedium Differential Collars
Exedium Front Antibumpsteer Kit
T1R Driveshaft Spacers
Custom PB Rear Camber Bar
RE-Works Front Strut Bar
Aero / Custom
Custom Rear Bumber
APR GTC-200 Wing
APR Carbon Mirrors
Custom PB Risers
Custom 4 Roll Bar with Harness Bar
Sparco Rev Seat with Custom rails
Innovative Engine/Transmission 70A mounts
T1R Magnetic Drain Bolts
Sparco 3 point harness
Custom Racing Dash with Oil Press Gauge
S2000 CR Belt
Lightened -150kg
-Aircon
-Radiator
-Shaved trunk
-Custom dash
-Airbags
-Custom OEM hood with Aerocatch
Brakes
Grooved rotors fron/rear
Carbotech XP10 - XP8 pads
HELL braided hoses
Custom brake ducts
Cooling
Mishimoto Radiator
Mishimoto Racing thermostat
Mishimoto Racing fan switch
Mishimoto Racing radiator cap
Drivetrain
Custom 4 puck clutch with lightened flywheel
4.77 Final Drive Ratio
Modifry Red Line Shift Beeper
Modifry Yellow Jacket
Wheels/Tires
Wedsports TC105N 17x8, 17x9
We need to see vids of your car on Laguna! Any POV's?Time Attack S2000
Engine
AEM EMS 1052U
Cylinder Sleeves
Oil Catch Can
Oil Pan buffles
Modifry Temp Fix
Suspension
Powerflex Bushings
Aero / Custom
Custom Rear Bumber
APR GTC-200 Wing
APR Carbon Mirrors
Custom PB Risers
S2000 CR Belt
Lightened -150kg
-Aircon
-Radiator
-Shaved trunk
-Custom dash
-Airbags
Brakes
HELL braided hoses
Custom brake ducts
Cooling
Mishimoto Radiator
Drivetrain
Wheels/Tires
Oh yes...I watched that video about a trillion times before, the guy is a helluva driver too!
Thanks, man.
I have never been to a track of any kind in my life...never even seen a dyno or anything. I probably should! Ha ha...
The exhaust I wanted was the Greddy SE...but it was nowhere to be found AND double the price of everything I got on the car in one shot. I'm happy!
DSC_0836 by swimex37, on Flickr
Thanks, man.
You got the perfect tool for the job. Try autocross first if you want better experience at slower speeds. The great part is you get a year's worth of learning from 1 event. You can't ever push that hard on the street!
Jul 16, 2017 07:33 AM
