(Anyone) Winding down windows with remote
im wondering if anyone has tried this yet, im referring to using the 3rd gen stock key fob to wind down the windows & open the sunroof...
i held the open button down, it rolled the windows down half way, held it down a second time it rolled the windows down all the way & opened the sunroof
tl_from_hell (03-05-2012)
justnspace (12-19-2011)
I do it too.
BTW, you can reverse it with putting the key in the driver side lock, turn it to the lock position to lock the car, release, then turn it again and hold. It will close everything. Boooyaaahhh!
lol, yea i just figured that out also, my co worker has a 2nd gen tl & he is fuming that his cant do it
There is also a window module that you can purchase for $40 that will allow you to roll up your windows from your key fob instead of having to stand and put the key in the drivers side door.
It's called KP Technologies Window Roll-up Module
The following 3 users liked this post by vietxquangstah:
^^For the new guys, Roger is an avid customizer. This is NOT a factory feature of the TL.
Jeez, Roger. Why you gotta get the new guys all riled up?
BTW, KP Window RollUp Module FTMFW!!!
press unlock button, press unlock again and hold, all 4 windows and sunroof should roll down/back. Works great when you want to get rid of the hot air built up inside and i love using it to show off to my friends
Mrtastygoody (12-17-2011)
Is there a trick to closing the windows with the key? I tried opening all the windows with key in door and worked. I then reversed direction and nothing closed.
Did you turn the key once to lock then back up to neutral position then lock-hold?
What up Dave!
Do you have to hold the lock button? or do you just tap it twice and it auto closes?
Me too
Not if you have the shaved key mod
It's awesome. Highly recommended.
Same here
Same here
What exactly is the procedure to make the windows roll up when using the KP Technologies module? Why is it hard to get down even after a year of ownership? Just wondering
I loved this feature but hated the short range of the stock remote. I upgraded to a high end Clifford/Viper alarm so now I can do up or down from a few hundred yards away. Sadly, I have to push buttons four times instead of two but it's well worth it.
the KP Window RollUp Module doesn't include a rain sensor AFAIK - did you mod the mod?
What about the sunroof? It opens with the remote so how are you getting it closed with the KP Window RollUp Module since it only does the windows? Another mod to the mod?
It works off the lock pulses of the car, so you can also activate it by pushing the lock button on the car door (interior) twice. I have done this when getting out of the car right before swinging the door closed.
BartmanEH (03-06-2012)
