anyone feel like there is overcompensation in the steering on the highway?
I feel as though there is TOO much power steering when banking in turns on the highway .. much much different the the type S .. enough to make me use BOTH hands at 2 and 10 o'clock to make sure I don't accidently oversteer into another lane.
Doesn't this car have speed-sensitive steering like the TypeS? Seems like's it's on overkill sometimes .. although it's very nice when I need to park w/ my 18's .. provides ample power to make parking a breeze.
Just took my first hwy drive down to Winfield and after the first on ramp, I was comfortable with the steering. TL seems to steer itself at hwy speeds. Hard to keep under 80 though!!
ZHP 4CE
Re: anyone feel like there is overcompensation in the steering on the highway?
Yeah, I noticed the same thing. The TL does have variable assist power steering, but I don't think it's nearly as good as on BMWs or the new RX-8 (which is probably the best one I've felt).
you got that right about keeping it under 80. just passed the 600 mile break-in mark and damn does this thing love to go. so smooth. it is a supreme highway burner. not a cruiser like a ls 430 because thats all about comfort trust me. but the person who can drive slowly on the highway in a tl is someone I dont want to know. it makes you want to drive it for any reason or none. only flaw is the pitiful turning radius.
Received 2,329 Likes
I miss the power steering on the older Hondas (say pre 1990 or so).
Past about 45 mph, the power steering basically shut off and you had PERFECT road feel without any boost and yet the car was light enough that you could steer it easily if necessary. Just a bit of a tug was all you needed.
Not sure if this is relevant or not, but I was driving down a stretch of highway a few weeks back (at night) at 75 MPH and as I came around this one curve, a damn Mountain Lion ran across the lane in front of me (thank God for HID headlights). Even at 75 MPH, my evasive manuever to avoid it was very crisp and responsive without getting the least bit "out of control". I was very impressed with its ability to get around this thing like it was a slolam course. Just thought I would share my experience.
Yes, definitely over compensated. If you think it's bad, wait until you take it up to 120mph - 130mph, you can't feel the road at all. Some have suggested getting new sticker tires will help.
Do you mean lack of road feel, too much power steering boost or a "quick" steering (ie twitchy) ?
Each successive TL generation has had less road feel through the steering wheel. I love my 1st generation, I feel road imperfections the way they were intended.
The 3rd generation TL doesn't have any roadfeel, it feels too much like an arcade game.
Too much steering boost .. w/ the 18" wheel/tire setup .. i've regained some more road feel thanks to the lower profile rims. The whole highway overcompensation deal is a bit disconcerting b/c sometimes I just like to rest the weight of my hand on one side of the steering wheel (as I used to do in my TL-S) and just bank into a turn .. however, if I do that NOW, the weight of my hand will totally cock the wheel way too much to that particular side and nearly steer me into another lane.
As I mentioned above, I miss the older Hondas. NO steering boost past 40 or 45 mph! Felt GREAT!
Not to inflame the FWD vs RWD dilema, but in a powerful FWD car like the TL lack of ultimate road feel is a given. For a FWD the TL has amazing feel. Compared to my previous TLs feel is much improved. In my previous car you could only tell understeer was occurring because the lack of directional change, you couldn't feel it through the wheel at all, it was very unnerving in high speed twisties. My 6 spd, on the other hand, hardly understeers at all and when pushed past its limit you can feel it coming.
Like I said, I'm probably mis-remembering...
Retired MOD
1 Post
Re: Re: anyone feel like there is overcompensation in the steering on the highway?
Originally posted by SCWells72
I'm probably wrong on this, but didn't Acura change the steering from speed sensitive to torque sensitive with the Type-S. I'm pretty sure my 2000 TL-P was speed sensisitve, and the press releases for the TL-S were tauting the virtues of torque sensitive steering over speed sensitive steering because it more accurately reflected the times when you really wanted firmer steering feel.
Here the best info I can find: Sorry I can't give personal opinion because I don't own the car
The 2004 TL uses new speed-sensitive, torque-sensing, variable power-assisted rack and pinion steering. The engine-driven variable-output pump provides steering feel preferred by driving enthusiasts: modest steering effort at low speeds and precise feel at higher speeds. The steering feel is very linear and evenly weighted.
Hydraulic steering dampers built into the system further improve stability during cornering and at high speeds. A one-way release valve decreases kickback in the steering wheel that can be caused by road irregularities. The hydraulic valve closes when it senses road irregularities, impeding disturbances to the steering wheel.
Increasing the stiffness of the steering gearbox mounting and the rear sub frame also maximizes steering linearity.
rockyboy
08-04-2024 10:35 AM
rockyboy
01-25-2016 06:00 PM
