Amzoil drop-in air filter for 3G TL?
I heard there is an Amzoil re-usable washable air filter available for the 3G TL that fits in the stock airbox. Is this true? It's not a K&N style with typical poor filtering is it? What is the part # and where do you get these? I've been using the standard Acura filter but hear that it's slightly restrictive. Thanks. Steve
~Da Nocturnal Cheetah~
2006 ACURA 3.2TL 3.2L 6-cyl Engine Code J32A3
FILTERS
Oil Filter:EAO13Absolute Efficiency Oil Filter
Oil Filter:51356WIX 51356 Oil FilterAir Filter:49063WIX 49063 Air FilterCabin Filter:24815WIX 24815 Cabin Air Filter
NGK PLUGS & WIRE SETS
Wire Set..........WIRESETN/RN/R[1]
1.No Wires Req'd
TRICO WIPER BLADES
Blade ClassDriverPassengerRearNEOFORMT16260T16190EXACTFITT261T191WINTERT37260T37190OKTANE24 inch18 inch
LUBRICANTS & FLUIDS
Engine Oil
Grade 1......API*
100% Synthetic 0W-20 Motor Oil
SAE 5W-20 XL Synthetic Motor Oil
SAE 0W-30 Synthetic Signature Series Oil
All Temps......5W-20
Manual Transmission,.....GLS[1]
AMSOIL Synthetic Synchromesh Transmission Fluid
Automatic Transmission.....SLF[2]
Synthetic Automatic Transmission Fluid
Fluids
Power Steering Fluid.....PS
Brake Fluid.....HB
Series 500 High Performance DOT 3 Brake Fluid
Clutch Fluid.....HB
1. Acura Manual Transmission Fluid, P/N 08798-9016A
2. SLF is Honda ATF-Z1 Automatic Transmission Fluid, Part No.
08200-9001
CHASSIS LUBRICATION
0-1 Fittings, 0 Plugs..........LM
Series 2000 Synthetic Racing Grease
Synthetic GHD Heavy-Duty EP Grease
Synthetic Multi-Purpose Grease NLGI #2
CAPACITIES
Engine, with filter..........4.6 quarts[1]
Cooling System, W/ MT Initial Fill..........6.7 quarts
AMSOIL Antifreeze and Engine Coolant
Cooling System, W/ AT Initial Fill..........6.8 quarts
Automatic Transmission, Initial Fill..........3.2 quarts[2]
Automatic Transmission, Total Fill..........7.4 quarts
Manual Transmission, ..........4.6 pints
1. After refill check oil level.
2. With the ENG at operating TEMP, shift TRANS
through all gears. Turn ENG off and check fluid level
within one minute. Add fluid as needed
TORQUES
Oil Drain Plug.....29 ft-lbs
Manual Transmission
Fill Plug.....33 ft-lbs
SERVICE INTERVAL
AMSOIL Product Recommendation and Drain Interval Guide (g1490)
OTHER TOP QUALITY PRODUCTS
Mothers® Car Care Appearance Products
FILTERS
1.No Wires Req'd
TRICO WIPER BLADES
LUBRICANTS & FLUIDS
Engine Oil
Grade 1......API*
Fluids
Brake Fluid.....HB
Clutch Fluid.....HB
08200-9001
CHASSIS LUBRICATION
CAPACITIES
TORQUES
Manual Transmission
SERVICE INTERVAL
Originally Posted by cristphoto
Thanks for the fast response guys. Nothing is listed other than the WIX which isn't an Amzoil reusable. Wonder why WIX is listed on an Amzoil site?
B. Why Wix? Here's why:
In the last three years, AMSOIL has introduced more new products and made more technical advances than during any other period in the company’s storied 34-year history. AMSOIL now provides engine oils for nearly every application, multiple gear oils, greases, fuel additives and appearance products. To offer a more wellrounded selection of automotive products, AMSOIL also offers high quality products from other manufacturers such as Twin Air, Donaldson and WIX. Recently, AMSOIL’s focus has been on the filtration market. The recently launched Ea Filter line includes the finest filtration products in the world for the auto/light truck market, and Donaldson covers the heavy-duty market. To complement the Ea line of filters, AMSOIL now offers WIX filters, allowing one-stop shopping for automotive customers. AMSOIL carries over 700 WIX air, oil, fuel, racing and transmission filters for automotive and light truck applications.
A History of Excellence
WIX is well-known around the world for its innovative filtration products for the automotive and light truck market. Founded in 1939, the Gastonia, N.C., company
earned acclaim during World War II when it created an oil filter out of a paper tube, wooden plugs and yarn when steel was in short supply. In 1954 WIX created the revolutionary spin-on oil filter that was eventually adopted as original equipment on most vehicles.
Today WIX manufactures some of the best air, lube, cabin air, hydraulic, fuel, crank case breather and transmission filtration products on the market. The company is also widely known for its support of NASCAR.
Superior Construction
WIX oil filters have a full metal base plate for superior strength at the double seal. They also feature a silicone anti-drainback valve that stays flexible in extreme temperatures. This improves oil flow and keeps oil in the filter to prevent dry starts.
WIX oil filters use an up-front by-pass valve. This design is superior to top-mounted valves because it helps to keep oil from washing past dirty media and entering the engine. The glass-enhanced media in WIX oil filters offers greater efficiency, capturing more 10 to 12 micron sized particles than other cellulose/synthetic blend medias. They also have a coil steel spring to ensure internal filter parts are sealed properly.
WIX panel element air filters have a linear path through the filter for low airflow restriction, a specially formulated adhesive to form WIX’s exclusive pocket pleat for the filter media and a soft sealing urethane gasket molded in place on the filter element.
Radial air filters are constructed of mesh screen on the inside wall diameter for element strength and media protection from backfire. Each round filter is manufactured with heat-resistant plastisol with specially designed crush seals on the top and bottom walls and adhesive seal joining the media ends. Additional Filtration Products AMSOIL offers WIX filtration products for auto/light truck and racing applications. This includes not only standard air and oil filters, but fuel, transmission, cabin air and filters specially designed for racing as well.
Fuel Filters
WIX fuel filters provide unmatched fuel cleansing performance. They prevent pump wear, injector clogging, premature engine wear and help boost fuel efficiency. WIX fuel filters offer quick, easy filter replacement, long life and the possibility of extended service intervals. WIX spin-on filters reduce the possibility of improperly installed cover gaskets, and they provide effective, easy draining of excess water on filters equipped with the drain plug. The superior materials, design and construction of WIX fuel filters provide excellent performance under all types of operating conditions.
Transmission Filters
AMSOIL will also offer the full line of industry-leading WIX transmission filters for passenger cars and light trucks. WIX transmission filters provide superior protection for many transmission applications in the auto/light truck market.
Cabin Air Filters
AMSOIL now carries the entire WIX line of high-efficiency cabin interior air filters for passenger cars and light trucks. See Cabin Air Filter Installations (2MB PDF)
Additional Information
WIX filters are supplemental to AMSOIL Ea filters, but now AMSOIL will offers WIX filtration products that cross to an Ea filter. With the exception of WIX lube filters, all WIX filters should be changed in accordance with original equipment manufacturer’s (OEM) recommendations. WIX lube filter change intervals are extended OEM recommendations to match the drain intervals of AMSOIL XL Motor oil. To find the correct filter for your application, consult the Online Product Application Guide.
WIX Racing Filters Click here for pricing and to purchase
AMSOIL is carrying WIX racing filters in addition to filters for more common automotive and light truck applications. WIX has been a part of racing and
NASCAR for many years, both as a sponsor and in the race cars. The company’s long-standing relationship with NASCAR not only demonstrates that WIX filters are high-quality products, but it also shows WIX’s dedication to racing, making it a perfect match for AMSOIL.
WIX is an associate sponsor of the Joe Gibbs Racing No. 18 car driven by 2000 Winston Cup Champion Bobby Labonte in the Nextel Cup Series. WIX is also an air filter contingency sponsor in the NASCAR contingency sponsorship program, awarding cash prizes to WIX-sponsored drivers in the Nextel Cup, Busch Grand National, Craftsman Truck, Winston West and Busch North Series that finish in first, second or third place.
WIX also sponsors Joe Gibbs Racing’s No. 20 car driven by 2005 Nextel Cup Champion Tony Stewart, along with Richard Childress Racing, Bill Davis Racing, Dale Earnhardt, Inc., Evernham Motorsports, Hendrick Motorsports, Roush Racing
and Robert Yates Racing in NASCAR’s Nextel Cup Series.
WIX racing filters are specially designed for racing applications and are not intended for normal driving applications. AMSOIL will carry all WIX racing filters, which includes 10 oil, 14 air and 2 fuel filters.
WIX Racing Filters Cross Reference Guide (66k PDF)
rcs86
08-02-2016 06:52 PM
