Airbag replacement
Old Jan 15, 2009 | 05:45 PM
sunnyb91's Avatar
Airbag replacement
how much does it cost to replace the front and side curtain airbag?
Old Jan 16, 2009 | 12:25 AM
DasTeknoViking's Avatar
airbag is about 700 for the drivers side and around 1K if I remember right for the curtain bag. You need to drop the headliner partially to do this. You are looking at good 500 bux in labor alone to just install the bags.
All said and done, expect about 2500-3000 bux for both of these AND then you STILL need a SRS control module. Once the airbags blow, it sets a code in the SRS computer that CAN NOT BE ERASED. This module ranges from 300-600 bux depending on year of car. Its located DEEP in the center of the dash under the radio. That will set you back another 400 bux to install.
Count on around 3500-4000 to fix the 2 bags and the SRS module.
Why do you ask ?
Old Jan 16, 2009 | 01:23 AM
carlos9827's Avatar
2011 BMW 335i
Why do you ask ?
Damn!!! I didn't think it would cost that much. No wonder why they total cars when air bags get deployed.
Old Jan 16, 2009 | 01:51 AM
blue.fired's Avatar
Lazy Idiot
It is cheaper to get some silicone injections!
Old Nov 20, 2012 | 12:51 AM
drosenseo's Avatar
5th Gear
i am about to put in a passenger side curtain airbag in my rdx. i expect it all to cost under $400 MAX. Probbaly closer to $300. The used curtain from junk yard is only $100!
Old Nov 20, 2012 | 01:01 AM
paperboy42190's Avatar
just install it yourself if you are mechanically inclined...not too hard. however if its your first time, then no dont do it its dangerous
EvilVirus
Dec 10, 2015 07:38 PM
IIDXholic
Sep 19, 2015 10:18 AM
jaynatlanta
5G TLX Problems & Fixes
Sep 15, 2015 11:08 AM
Sep 14, 2015 10:09 PM
SpraykwoN
ILX
Sep 11, 2015 08:45 PM
