Air filter replacement
Old Nov 17, 2007 | 01:22 PM
jetblakTL's Avatar
The Darker the berry....
Can someone point me to some instructions on changing the air filter(s) in an 06 TL? The manual doesn't have any info and I can't seem to locate any info here either. Maybe I'm blind? ;-) Also, how often are you supposed to replace it? Thanx.
Old Nov 17, 2007 | 01:31 PM
ggesq's Avatar
Alot of questions are answered in the Garage: https://acurazine.com/forums/showthread.php?p=1159175
Please do a search next time. Thanks.
Old Nov 17, 2007 | 01:42 PM
06 Acura TL's Avatar
REDBULL///AMG
i would replace it every 25K. but thats just me.
Old Nov 17, 2007 | 01:54 PM
jetblakTL's Avatar
Never mind - I figured it out - I got confused because I kept hearing everyone say that the intake was behind the front driverside tire. What a stupid design by Honda - to squeeze the filter up in between the battery and fuse-box and to connect it to the intake tube so you have to wrestle the entire assembly to get the filter cover off and the filter out. Why not just give it a nice simple flip open door so you could slide the filter out?
Anyway - suggestions on type of filter - will a Fram or Purolator do?
Thanx, mod - I didn't see the garage.
Old Nov 17, 2007 | 02:30 PM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
Fram or Purolator should be just fine. A K&N Drop-In is also an option. You can use it for the life of your car.
Old Nov 17, 2007 | 03:42 PM
u1arunit's Avatar
Car Guy
Replacement intervals vary largely on what type of driving you do. I change mine every 15k-20k miles and it's usually pretty dirty at that point. Rule of thumb is that if you hold it up to light you should be able to see light down between the pleats in the filter for it to still be good to use.
Old Nov 17, 2007 | 11:59 PM
darksom1's Avatar
~Da Nocturnal Cheetah~
Every 15K man...keeps it freshly, fresh!!!
GET 'ER DONE!!!
Old Nov 18, 2007 | 06:51 AM
SouthernBoy's Avatar
Registered Member
I change both my engine and cabin air filters once a year which generally works out to around every 14,000 miles. I inspect them each time to see if I need to vary the interval. The cabin filter is usually the dirtier of the two.
Old Nov 20, 2007 | 02:22 PM
fish008's Avatar
I just did the K&N drop in filter change and I couldn't help but notice how much thinner the K&N was compared the the stock filter. When I droped it in it fit perfectly but I was thinking the whole time that this think is going to jump around in here because its thinner. Oh well, it works and the car is breathing better so who cares.
Abe_Froman
Sep 16, 2015 01:27 PM
Skirmich
Sep 15, 2015 06:41 PM
Aleax
Sep 9, 2015 08:04 PM
sputik
Sep 7, 2015 01:40 PM
bymotion
Aug 31, 2015 05:00 PM
