Air Filter change on 2004 TL
What is the easiest way to change the air filter on the TL? There is a plastic strip on the driver side fender that seems to be in the way of getting the filter out. I can't seem to be able to remove that strip due to the 2 clips holding it in place.
Replaced mine fairly easily. I recommend removing the bracket holding the battery down closest to the air filter assembly. Once all 4 screws are loosened, lift the upper portion of the air filter box and pull towards the left tire. Good luck.
Overlord - Team Abyss
Originally Posted by rimz
damn, now i'm confused...i thought our air filter was behind the glovebox...or am i thinking of a different air filter on our car...?
Abe_Froman
09-16-2015 01:27 PM
HydrasunGQ
09-14-2015 10:14 PM
