Air Conditioning Filter Change
Old Jun 25, 2008 | 04:17 PM
GVtech's Avatar
Talking Air Conditioning Filter Change
Just wondering if there is a thread on how to change the AC Filter? Saw one thread that said it had instructions but didnt see a link.
Old Jun 25, 2008 | 04:41 PM
csmeance's Avatar
there DIY (do it youself's) in the 3G garge link above. It is fairly simple, also nice last name in the username, we share the same...
Old Jun 25, 2008 | 04:52 PM
01tl4tl's Avatar
look for Cabin Air Filter in gen3 gargae section or gen2 DIY section
Its simple- buy new filters (come 2 in a box-thats what you need) at zone -under 20 bucks-
remove glovebox door and box- remove panel over filters- first time requires scissors to cut away tabs, remove filters in their slide tray- use shop vac to remove the leaves and crud- Install new filters in stock tray- slide tray in
turn plastic cover 90 degrees so end tabs go in slot `c ` now, and screw holds top in!
Glovebox back in.... and done
use cushion for knees - its 20 minutes bending and leaning the first time
then each year its 10 minutes to pop in new filters
Old Jun 25, 2008 | 04:54 PM
Fulani has a TL's Avatar
by same user.
https://acurazine.com/forums/showthread.php?t=182984
OP: You need to give some time in order to get responses, you cant expect a response in 2 minutes.
Btw: not trying to be harsh, just trying to help you out and prevent others to hate.
Old Jun 25, 2008 | 07:05 PM
DMZ's Avatar
DMZ
Head a da Family
Did mine just last week. Took me about a half hour. Follow the DIY thread.
Old Jun 25, 2008 | 07:21 PM
ggesq's Avatar
OP made two threads -repost. This thread is closed.
rockyboy
Aug 4, 2024 10:35 AM
Feb 25, 2020 09:57 AM
nanos
Nov 12, 2015 08:41 PM
PortlandRL
Sep 14, 2015 12:01 PM
Aleax
Sep 11, 2015 11:31 AM
