Aftermarket ATF (i hate cars chime in!)
#44
Mine was well on it's way before the idiot tech installed 3 quarts of Z1 in mine instead of the ATD I left for him. Now I have to do at least one more drain and fill, maybe two more to be safe.
To ease my mind going that long, I've installed a magnefine inline trans fluid filter to take care of any contaminates.
#45
Yes, but you can safely go 100,000 miles before replacement. At that mileage it will still be in better shape than Z1 at 20,000 miles.
#46
Z1, judging from it's performance has a very poor base oil. This is the opinion of many who are better educated than me.
The only factor that would go against leaving it in for 100K+ miles would be the possible contaminate load which is usually low for a transmission anyway.
#47
In certain scenarios, it's capable of 300,000 in vehicles with large sumps. It's a synthetic straight weight oil so it won't shear down over time and it doesn't oxidize (well barely). Sheer and oxidation are the two main reasons for having to change an ATF.
Also.. any opinions on Royal Purple?
#48
I'm definitely going to have to do some serious research about the subject. Were you able to take a look at your ATF when you took it in? I'd be real interested in knowing what condition it was in. The Z1 fluid seems to turn dark / sludge pretty quick from what other members have posted.
#49
Do you recommend that I get the fluid from the Amsoil online store? Seems pretty pricey - ~$200 for 3 gallons, so I'm not sure if there's a cheaper alternative.
#50
#54
Here's some fuel for the fire:
Amsoil ATF
I have been using the Amsoil ATF for over 25,000 miles now and can tell you some of my own personal findings. I drained and filled the transmission three times and finally kept the fourth fill in so I believe I only had Amsoil ATF in the transmission. With 42,000 now on the odometer, I started to hear a whine noise; therefore, I pulled the transmission dipstick and saw the fluid very dark, almost black in color but with no unusual odor. I freaked out and sent in a sample of the fluid to Blackstone for their comments and findings. They sent back the results of the analysis which shows no breakdown in the fluid and that the fluid is fine except for the fact that the aluminum content in the fluid is over three times the average it should have. Blackstone indicated that the high aluminum in the ATF probably is a torque converter problem.
I then sent in a sample of the fluid directly to Amsoil for technical analysis. They determined that the fluid is fine, is o.k. for continued use and they don't know why the aluminum content is high. They also noted a high aluminum content but did not state any comments about the high number.
Anyways I called Amsoil and they stated that I have no claim as far as the oil damaging the torque converter and that the oil is o.k. for continued use. I stated that the oil is not correct for my application and that's probably the reason I have the whine and high aluminum count in the fluid. Anyways they denied my claim and said they will continue to endorse Amsoil in Honda applications requiring Z-1 fluid.
I was lucky as I drained and filled my transmission with Honda Z-1 fluid and brought the vehicle to Honda. They have never seen a Honda CRV transmission whine and were really surprised when they saw my relatively low mileage. The technician was really nice and goodwilled my transmission and torque converter with another torque converter and transmission even though I am outside the warranty period. The whine is gone and the transmission shifts a little more firm.
Amsoil may make some good products but I can tell you that I will not use their ATF in my Honda CRV ever again. I now believe in Z-1 only in my CRV transmission.
Amsoil ATF
#55
Amsoil ATF
Amsoil ATF
So I found a virgin oil anaylsis of ATF and Z1 and the Z1 has much more zinc and I believe phosphorus or calcium but I can't remember it's been so long. Anyway, the ATD contains more of those two additives and that was my original reasoning choosing it.
FWIW, my TL has had a whining noise that is dependent on engine rpm, not wheel speed since I bought it with 8 miles on it. It may be the convertor but it seems like a lot of TLs do this. The ATD made it a little quieter, probably because it's thicker. Not saying if it's a good thing or not but it hasn't gotten any louder at 71,000 miles.
#58
Amsoil ATF
Amsoil ATF
#59
Soul_Deamon
11-13-2018 04:44 PM
nanos
11-12-2015 08:41 PM
