Advice on Good Car Jack
Hi,
I am trying to do some maintenance underneath my car for the first time and I would like to see which hydraulic jack you guys use?
I purchased the 2 ton Torin brand jack, tried to jack up the front of the car at the tow hook area, but it doesn't go up high enough for my jackstands to be placed on the front sides.
I am going to return it, but would like some advice on which brand to get and which size, etc. Thank you!
AZ Community Team
Received 7,771 Likes
I got a Sears 3 ton jack. It's OK for light/home duty, but reviews on it are spotty for durability.
Regardless, you need a jack that has max lift height of 20" (or more) if possible. The one I have is 19 3/4" and I can barely get the rear high enough for jack stands.
I have to put a block of wood on the jack and/or raise the front first.
And, BTW, you don't "jack up the front of the car at the tow hook area" - hopefully you meant the rear. The front get's jacked on the plate in the center front frame.
If you're dropped much, you may need a low profile.
Dogmatic Dinosaur
I have an older version of this one and it works great. No complaints except that mine is dirty now.
http://www.amazon.com/OTC-1532-Capac.../dp/B000XSCEBM
Dogmatic Dinosaur
It says 18 inches. I dunno if mine is the same since it is older, but I can jack up any of my 4 cars with it enough to get jack stands underneath.
AZ Community Team
I also want to revise my earlier post. I do have the Sears 3-ton jack and it does have a lift height of 19 3/4". BUT the car I couldn't lift with a shorter jack was the 2G TL-S (rear).
The 19 3/4" does lift the rear of the 3G TL-S high enough for wheel removal and jack-stand placement.
Although, if I were doing it again, I would still go to 20" if I could.
6spd FTW
I have one of the craftsman aluminum low profile "race" jacks. It's red and silver, has bad reviews for durability online but mine has yet to let me down. Fits under the front and rear of the car to the jack points and also lifts way higher than my jack stands.
Hi,
I got Harbor Freight 2 ton Low profile Racing Jack for like and 2 pairs of 3 ton stands all for like $197. It lifts 18 3/4" I believe. Enough to fit the stands and a click up. It does the job pretty well but if your car is slammed you might have some trouble fitting the jack to get to the front jack point.
winner
boo walmart
low profile 1.5 ton jack from harbor freight.
i would definitely purchase their extended warranty
those things are known to crap out, ive had 2 crapped out on me.
the warranty is 10 bucks for 2 years so if anything it's a return policy every 2 years for their new model
AZ Community Team
You couldn't pay me to use a 1.5 ton jack. 2-ton at least.
I'd prefer the jack have a capacity equal (or greater) than the full weight of the car. Same for jack stands, which I believe are rated as pairs.
But maybe that's just me.
winner
MY BAD.
AZ Community Team
winner
the sad part about my usage of jack stands isn't that i'm afraid of the jack failing, i have a fear of an earthquake happening during me sitting under my car and having the freaking tire in my face and my aspec kit smash into my chest.
i'm looking for a pair of decently priced wheel chocks though... amazon has torins at a steal for 3 bucks but ships in 7-9 weeks, lol.
check out this new car jack: http://www.youtube.com/watch?v=D0SblGp8Oy0
boo walmart
Your Friendly Canadian
Received 1,491 Likes
That jack in the video is good, but I wish the stand had an adjustable height feature.
B A N N E D
flat rack/4 post or a two post one
cause i know one of my lifts at work, i actually have trouble getting under my car, but the other one is good
BUT then it is reversed with 4x4 with the extensions, especially when they having running boards, easier to get the one i have trouble with my car on, under the 4x4's
Soul_Deamon
11-13-2018 04:44 PM
