Acura TL Headlight
Acura TL Headlight
Hi guys, so this weekend I took apart my bumper to install my new HIDs and CAI, it all went great but it took a little longer then it should of i think cause it was my first time pulling off the bumper and it was a bit tricky. Installing the CAI and the new HIDs was easy, after installing everything i decided to turn on the car and the lights, soon after I noticed that my right headlight sometimes wont turn on (fogs work just fine). I read up on a few other posts that some people have been having some problems with their headlights and they mentioned that it might be the ballast or the igniter... If any of you guys have had anything like this how did you fix it?
I am also having another problem with my parking/ambient lights. When i turn on my headlights the right front signal light wont turn on, but when I use the signal indicator the bulb works. Does anyone know what this is, is it the bulb thats causing the issue? Any help is appreciated
Thank you!
UA6-MT (01-23-2020)
[QUOTE=h22lude;15565687]Hi guys, so this weekend I took apart my bumper to install my new HIDs and CAI, it all went great but it took a little longer then it should of i think cause it was my first time pulling off the bumper and it was a bit tricky. Installing the CAI and the new HIDs was easy, after installing everything i decided to turn on the car and the lights, soon after I noticed that my right headlight sometimes wont turn on (fogs work just fine). I read up on a few other posts that some people have been having some problems with their headlights and they mentioned that it might be the ballast or the igniter... If any of you guys have had anything like this how did you fix it?
QUOTE]
As far as the headlight, mine was the igniter that had failed.
QUOTE]
[QUOTE=dainmezron;15565775]
Alright, I think I'm going to pick one up and try my luck, hopefully thats what it is. Thanks
QUOTE]
QUOTE]
I just finished doing all the work, I have a good feeling that its the igniter, it used to do the same thing with the old bulb. When i turn on the light for the first time it works, if i turn it off and on quickly it doesnt work, but if i let it off for about 10-20 sec and then turn it on it works. If the new igniter doesnt work ill just take it to the dealer, its a pain for me to keep taking off the bumper and the headlights, mainly cause im in school and i dont have alot of time or the tools available all the time.
Registered but harmless
Received 1,102 Likes
![Blink](https://acurazine.com/forums/images/smilies/blink.gif)
I saw the Sylvania 7443s at Walmart this morning, but bought mine some time ago from an auto parts store. They can be found in hardware stores and probably Target too.
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
