accord fog light mod?
Old Feb 14, 2009 | 01:56 PM
luistypes's Avatar
Is there a reason why no one just wires the accord fog lights to the original harness so you can use the original switch?
Old Feb 14, 2009 | 03:47 PM
csmeance's Avatar
tapping into the original harnesses for power will put 2x the load on them and can cause a fire. The accord harness uses direct battery power to my knowledge so it does not strain the electrical system.
Old Feb 16, 2009 | 05:39 AM
luistypes's Avatar
OK, Thank You.
Old Feb 23, 2009 | 02:14 PM
04ABPtl's Avatar
I have the same question, and am not sure i fully understand the answer that was given, so sorry if this is a stupid question but... The 04 tl fog light is in the headlight but uses its own bulb, with an independent swith from the headlighs. so if you where to remove the connection to the factory fog and tap into, and extend that harness for power to the newly isntalled accord fog lights where is the problem. again sorry if this is a stupid question
Old Feb 23, 2009 | 02:29 PM
Tripnbeats's Avatar
nono hold on.... cs is correct but.... if you use the orignal wiring as a relay trigger it can be done without issues as long as you fuse your draw....OR put 2 relays to draw current off of the same trigger.
Old Feb 23, 2009 | 05:53 PM
bimmerman's Avatar
Traveling the country
+1
I would think just powering the relay to turn on would not be nearly the draw the lights normaly pull. I would NOT power the lights off of this factory wiring though.
InFaMouSLink
Oct 27, 2015 06:51 PM
sockr1
Oct 1, 2015 01:31 AM
ellisd03tls
Sep 8, 2015 04:17 PM
cruisingnycfl
Sep 2, 2015 12:11 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
