AC in the winter
Old Oct 27, 2009 | 09:33 AM
gdong's Avatar
AC in the winter
So I heard from a friend that you're supposed to run the AC compressor in winter once a week or so, in order for the oil to circulate and lubricate the system for maintenance. Is this true, and if so what is the technique you guys use? Just stick to auto + set temp + toggle ac button so that it's AC on?
Old Oct 27, 2009 | 10:21 AM
nugrahaa's Avatar
The A/C is always on/off (it works automatically) eventough heater is set on (by setting temp number higher than outside)
Unless you press the A/C button until the 'A/C OFF' displayed then the A/C is not working.
Old Oct 27, 2009 | 10:49 AM
01tl4tl's Avatar
good question G
Yes its true that you need to run the ac at least 30 minutes a month during winter to keep the seals conditioned- thats part of what its oil does. Failure to do so will result in leaky orings and loss of pressure/function and eventual serious $$ damage if left that way
In order to run it automatically, most car makers tied the defroster to the ac so when you select defrost- you get ac air pushed at the windshield
That will remove moisture from the glass faster than heat will, and heater operation requires some coolant temp--so the ac is the best choice
If you live where you never use defrost- then turn it on ac manually or set temp to 65 and drive.
There is probably info on this in the owner book- if you dont have one go to the Garage section here, and click link for free online version
Old Oct 27, 2009 | 11:08 AM
SouthernBoy's Avatar
Registered Member
Originally Posted by 01tl4tl
good question G
However, you can use your defroster without using the A/C if you wish. I do this frequently.
Old Oct 27, 2009 | 11:09 AM
Registered Member
Only true when using the AUTO mode. If using the manual mode, you have to manually set the A/C on or off.
Old Oct 27, 2009 | 12:57 PM
Pz_'s Avatar
Pz_
There are long stretches of time even in the summer that I don't use my AC, guess I better start turning it on sometimes.
Old Oct 27, 2009 | 01:49 PM
gdong's Avatar
good question G
Great information! I'm actually up in Toronto, Canada so I need to use my defroster very frequently in the winter. I guess this settles it. Thanks
Old Oct 27, 2009 | 02:20 PM
jkim23's Avatar
I usually keep the A/C on at all times; even when using the heater. It removes moisture out of the air and keeps the windows from fogging.
Old Oct 27, 2009 | 03:36 PM
Will Y.'s Avatar
Registered but harmless
Yes- the TL's A/C will come on when the defroster function is activated; you'll see the A/C symbol on the display when the defroster is used.
Old Oct 27, 2009 | 03:55 PM
T0L8's Avatar
Good information.
Old Oct 27, 2009 | 04:15 PM
Babnik's Avatar
Probably not a good idea to keep the a/c on ALL the time because it does make the engine have to work harder and use more gas.
Old Oct 27, 2009 | 05:16 PM
Registered Member
Originally Posted by jkim23
I usually keep the A/C at all times; even when using the heater. It removes moisture out of the air and keeps the windows from fogging.
I rarely use the A/C in the colder months, except for the times I want to exercise it, and my windows virtually never fog up during those months. As for moisture in the cabin air, I always use outside airflow so that isn't a problem either during the winter.
Old Oct 27, 2009 | 07:15 PM
Turbonut's Avatar
If you happen to be in and out of the car when you're covered in snow, the additional moisture content inside the car will have an effect on the inside of the glass, and the A/C will need to be activated, at least that's what I've experienced for many decades in the winter. Many years ago our Grand Cherokee lost an evap core in December, so I thought I'd wait until warmer weather to do the repair. Driving that Jeep was horrendous, even with the heater/defroster on max I couldn't keep the glass clear of moisture on the inside.
Yes, if you push the A/C off button, that's what you'll get, no compressor, that's why they have the windshield defroster symbol, push it and the A/C will activate.
Old Oct 28, 2009 | 12:29 AM
avs007's Avatar
Hardly... They did this on Myth Busters IIRC. The difference was negligible.
Old Oct 28, 2009 | 12:41 AM
JTS97Z28's Avatar
The TL's have auto climate control. Why would you use anything else but auto? Leave it on auto all the time and call it a day. Thats what I do.
James
Old Oct 28, 2009 | 11:22 AM
tet001's Avatar
8th Gear
AC on will make the windows defrost much faster
Old Oct 28, 2009 | 11:29 AM
Registered Member
Yes, if you push teh A/C off button, that's what you'll get, no compressor, that's why the have the windshield defroster symbol, push it and the A/C will activate.
I'm sure that would happen, however when it snows, my TL stays put in my garage and my Ford Ranger gets used.
You don't need to push the Defrost button to use the defroster if you have Nav. From the manual mode, just say, "Climate control defrost" or as I tend to do, "Climate control floor and defrost". You will get air directed to your windshield without using the A/C.
Old Oct 28, 2009 | 11:30 AM
Registered Member
James
Simple answer. Because you have the choice.
Old Oct 28, 2009 | 11:31 AM
Registered Member
In most cases, this is true. However, in the cooler months, I virtually never use the "Defrost" button.. I use the manual defrost setting without A/C and it works fine.
kev87a
Nov 2, 2015 07:40 AM
kev87a
Oct 18, 2015 02:03 AM
dirleton
20
Oct 16, 2015 01:48 PM
polish_pat
Sep 30, 2015 12:22 PM
jmaxima03
Sep 27, 2015 10:22 AM
