70k service
Whatever you do, don't fall for their A or B packages. What they do is they take advantage of the customer and charge 300+ dollars for an oil change and tire rotation. These are the services that should have been done in the life of the car besides oil changes:
30K:
Air Filter and cabin air filter change
60:
Air Filter and Cabin Filter Change
3X Transmisson fluid change (drain and refill 3x)
70:
Spark Plugs are recommended, but not necessary.
If you are handy (like if you can make a desk from staples/walmart) you can change the filters yourself. It is not hard and you can save quite a bit of money.
30K:
60:
70:
However, the manual says to change the engine/cabin filters with code "2," which comes up about every 25K-30K miles from what I've seen on my TL and here. The manual also requires a change of brake fluid every 3 years (time only, not mileage) and first change of auto transmission fluid at 60K (then every 30K thereafter).
I nevertheless think one is still handy if one can put together furniture from Office Depot, Target or K-mart...
