6sp shifts fine no 3rd gear problem, do I still change to gm synchromesh or honda MT
car shifts fine and I live in a warm socal (are these hard 3rd gear shifts mostly in cold weather places?)
Do I go with gm synchromesh friction modified or the new improved honda MT fluid? does the tranny take 3 quarts?
Registered Member
If you are not having any problems (like most I would bet), then it's pretty much a judgement call.. may wish to go with the "new improved" Honda fluid. I never had any problems either, but I have used the GMSFM fluid with both of my drain and fills.
Your manual doesn't take 3 quarts. I takes 2.3 quarts (2 quarts, 10 ounces) for a drain and fill, or 2.6 quarts for a dry fill. You would, of course be doing a draing and fill.
Lastly, those who have had the infamous 3rd gear problems have lived all over the country, so weather doesn't seem to be a real factor there.
If it ain't broke, don't fix it! If it's time to change the fluid, use the OEM Honda stuff. GM fluid is VERY expensive. I wouldn't bother trying it unless your having a synchro problem...
06 6mt A-Spec Navi
The new Honda fluid worked fine in mine, I don't have the 3rd gear problem just a little hard to shift into when its below freezing but once its warm its good to go
mada51589
05-03-2022 08:54 PM
Mike Bertram
09-10-2015 09:27 AM
HeloDown
09-08-2015 06:51 PM
