6 Speed Manual TLs build date
JDM FREAK
Hi guys,
Good news, I just got my 6 speed manual build date, which is October 28TH, and I shoud get it sometime in November or worst case late November.
One thing I did is change my car order, since that HP models are coming out first, I changed from Black/Camel, to Black/Ebony.
I don't know if you guys are aware that the HP model is equiped with an upgraded suspention, almost similar to the one in NSX, which makes the TL stick to the ground and have a great grip on.
Also, HP is going to have a different set of rims, also the HP model is about 1.5 inch lower than the stock TL.
I was just wondering if the upgraded suspension in the HP model is the same suspension in A-SPEC.
I assume that when you say HP model you mean HP tires. There are three versions of the 6MT. Standard, HP tires (Summer rubber and slightly modified suspension- slightly thicker sway bar) and the a-spec (lowered and completely differednt suspension and other goodies). The HP tire model is the same ride hight as the standard tire model from what I was told at the the ride and drive for dealers.
Is you car Navi???
Is you car Navi???
According to the Acura website the 6MT's all have the thicker sway bars and LSD and the HP tires are an additional $200. The only other option (other than A-spec) is the NAV. Am I missing something? What do you mean by "Standard" 6MT?
Puma Jim
09-26-2015 01:08 AM
