5w20 for better performance?
Is it possible for 5w20 weight to give better performance or throttle response compared to 5w30? I noticed when I had the dealership put in 5w30 (Mobil 1) that it didn't have the same pick-up and response as before. I am not sure if this is just some type of placebo effect or the added weight. Thoughts?
justnspace (08-23-2012)
I've been running Motorcraft 5w20 for over 70,000 miles with absolutely no issues what so ever. I would run Motorcraft 5w30 but they don't seem to offer the 5qt jugs in that weight anymore. However, I also change my oil and Purolator Purone filter at 3,000 miles. Heck my MID says my oil life is at 60%, but I'm absolutely anal when it comes to changing my oil.
Some people may say I'm just wasting my money, but I've always changed my oil at 3,000 miles and my old 90 accord is still running strong with 245,000 miles.
Yeah, 5w20 is likely to give you more power over 5w30.
However, the effects of this are likely to be <1HP. Good luck trying to notice that.
Lots of people on ecomodder report better efficiency with thinner oils, but of course that effect becomes more noticeable with a more efficient vehicle and driver. When you're getting 60+ MPG, and religiously monitor these things, you might notice a percent or two. It's a safe bet that reduced losses accounts for this increase in efficiency, which should also make for an increase in power that makes it to the wheels.
Appreciate all the replies guys.
I had the dealer put in 5w30 to see if it would quiet the engine a little since I've been getting some noticable valve tick on idle.
Dealer suggested a valve adjustment, but I may stick with 5w30 for now and just do the 105k service in a few months, even though I am no were near that mileage.
At my Walmart Mobil 1(the real Mobil 1) is $28 plus an extended wear filter that's $12. So my 3 oil changes to your one is only $26 more. Which to me I can live with.
Agreed.... Unless you live in Alaska and regularly drive short trips in -40 degree weather lol.
I wish I would've put Mobil 1 in since I bought the car. Because I can get it for a little over $3qt from the dealership my sister works at, but I've always been told to stick to one type of oil especially the higher the mileage, especially not to switch from dino to synthetic or vice verse.
OP, I wouldn't worry. I used to be a crazy "every 3k oil change kind of guy" but I change it now every 5k-7k.
Check out this article from edmunds.com http://www.edmunds.com/car-care/stop...-your-oil.html
That was a good read, but for my own piece of mind I'll continue my 3,000 mile oil change. Heck, even Honda recommends to change the oil at 3,750 miles under "severe" driving conditions, and basically starting your car is considered a "severe" condition.
IHC
If the noise is the engine and not injectors or a pulley, a heavier oil has a chance of quieting the noise. But remember, the oil can be 30x thicker at start up so if the car makes noise when cold or most of the way through the warmup process, the small difference in viscosity at full temp probably won't make a difference. Some oils are better at others at quieting noisy engines, depending on what is making the noise.
What oil do you recommend to keep the engine smooth and quiet, Redline? If so, should I stick with 5w20 or 5w30?
Fatfrii (08-24-2012)
Chapter Leader (San Antonio)
I believe it's valve ticking and a tech also thought that too. Sounds almost like a diesel from about 5ft away and seem to get a slight rattle/ticking when giving it slight throttle.
Any oil will work. It is all about the filter nowadays.
If you want to run a synthetic, make sure it is a TRUE synthetic. Some are labeled as Synthetic, but, in actuality, it is only a syn-blend. Mobil 1 EP, Amsoil Synthetic, or Redline Synthetic will be fine.
This is why I don't always go by what the dealer says. Starting your car is severe? Then what isn't? Watching it rust?
Obviously I was be facetious, but pretty much everything most people do daily is considered severe eg: driving less than 10 miles one way, extensive idling or sitting in stop-and-go traffic, and driving on dusty, muddy or de-iced roads. Also, it says all Canadians should follow the "severe" maintenance schedule.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
