Which 3rd Gen TL is the fastest? (year wise)
Which 3rd Gen Acura TL is the fastest year? I'm just looking to see if one year specifically is faster than the rest. I'm only interested in a normal automatic TL. I had an 04 TL, and loved it! Specs say the 04 car has 270 HP. I've read though that after 04 the way horsepower was determined was changed and the 258 HP for the 06 is equivalent to the 270 in the 04. Is there a difference? I want the fastest TL I can get with it still holding its class.
PS. If anyone has a 3rd gen pearl white TL they want to sell around the Minnesota area let me know!
Samething... Speed dont change on year.. on engine size though
04-08 base TL's all have the same engine with 258hp. Don't worry about the different numbers you hear because 270hp is based on an old standard.
That being said, the 07-08 base TL does have an updated transmission with MARGINALLY different gear ratios. It's not something most people will notice though.
just dont expect an 08 base TL to be any faster than your 04 TL.
If you really want more power then get a type S
The following 4 users liked this post by paperboy42190:
There is no difference. All 04-08 Base TL's are rated @258 HP. The SAE Rating system changed in 2006. This will help, A bit technical but a good informative read https://acurazine.com/forums/3g-tl-2004-2008-93/sae-new-horsepower-rating-system-3g-garage-a083-589568/
however if you look at part numbers between couple engine parts in 04-06 base tl and 07-08 base TL, some are marginally different. I'm sure its probably some differences to accommodate the refreshed transmission, but doesnt affect power in any way
the easiest way to find out which car is faster is to take the weight and divide it by HP use the same standard measure for each car. it is 258hp for base and 286 for Type S
generally speaking fastest to slowest acceleration
6MT type S
6mt/5at Type S
5at base
for entry level luxury, they do OK. the problem is Honda really has not been keeping up in the power department since the TL type S was introduced nearly 14 years ago...
6MT type S
6mt/5at Type S
5at base
The following 2 users liked this post by YeuEmMaiMai:
Acura_Dude (01-11-2014),
JTS97Z28 (01-11-2014)
The following 3 users liked this post by Paradigm TL:
Fastest to slowest:
6mt type s
6mt base
Auto type s
Auto base
The year doesn't matter.
6mt type s
6mt base
Auto type s
Auto base
I know 04-08 base motors all had the same HP, but if someone wanted to get technical, if there was a 04 or 05 3.5L Type S it may have been rated at 300hp using the old method :-)
The following 2 users liked this post by JTS97Z28:
paperboy42190 (01-11-2014)
It actually kind of was. The J35A8 (Type-S engine) was rated at 300hp under the old standard when it debuted in the 2005 RL.
The following 3 users liked this post by splew:
1fatcrxnem1
22
06-01-2018 01:23 AM
CaliAtenza
5G TLX Photograph Gallery
09-09-2015 06:48 PM
